ViewSonic PJD7828HDL 1920x1080 Full HD 3200 Lumens Projector
Quicklinx: C3HZWS00 Mfr#: PJD7828HDL
For an incredible audiovisual experience at a great value, the ViewSonic LightStream PJD7828HDL projector delivers. Perfect for home entertainment, this projector features 3200 lumens, Full HD resolution, an intuitive, user-friendly design, and a sleek chassis. The SuperColor technology offers a wide color range for true-to-life image projection in any light, while SonicExpert, powers a 10 W speaker to deliver incredibly clear and audible sound. With a shorter throw ratio, 1.3x optical zoom, smart design, and extensive connectivity, the PJD7828HDL provides flexible and quick setting up in any home.
  • Great color accuracy
    ViewSonic's proprietary SuperColor technology offers a wider color range. With a 6-segment color wheel design and dynamic lamp control capabilities, SuperColor technology projects images with reliable and true-to-life color performance, in both bright and dark environments, without sacrificing image quality.
  • Stunning resolution and brightness
    This projector features Full HD resolution for sharp and clear picture. It is perfect for watching high-definition content, including movies, videos, sports, games and TV, without any distortion or scaling of the original video format.
  • SonicExpert technology
    This LightStream projector is designed with SonicExpert technology that incorporates an enlarged speaker chamber and a more powerful amplifier. An integrated speaker captivates your audience with immersive sound.
  • PortAll: discreet wireless streaming
    This projector includes ViewSonic's PortAll feature - a hidden compartment with an integrated and secure MHL/HDMI port that lets you discreetly stream multimedia content from a wireless dongle, or lets you connect to other devices via an HDMI cable. What's more, an integrated Micro-USB cable lets you quickly and easily power other Micro-USB devices.
ViewSonic LightStream PJD7828HDL - DLP projector - 3D
DLP projector - 1080p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Keypad
Bundled Services
1 year Express Exchange Service
Americas
Brightness
3200 ANSI lumens
Contrast Ratio
22000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours (30-bit)
Bulb type
210 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
S-Video, composite video
Speakers
Speaker(s) - integrated
300 Watt
31.6 cm x 22.8 cm x 10.37 cm
2.4 kg
3-year warranty
3D Capable
Built-in Devices
Keypad
Bundled Services
Americas
Projector
Brightness
3200 ANSI lumens
Contrast Ratio
22000:1 (dynamic)
Image Size
76 cm - 762 cm
Projection Distance
1.29 m - 14.28 m
Throw Ratio
1.15 - 1.5:1
Resolution
Full HD - Full HD (1920 x 1080) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
210 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction, zoom, focus
MHL compliance, SonicExpert, PortAll, ViewSonic SuperColor, elevation feet
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.3x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x HDMI - 19 pin HDMI Type A , 1 x USB - mini-USB Type B (management) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15)
Cable cover, wireless remote control
1 x VGA cable
Security Features
Security Slot Type
Kensington security slot
C-Tick, NOM, SASO, TUV S, CB, CCC, PSB, FCC, RoHS, KCC, WEEE, cTUVus, REACH, KC, ERP, CECP, EAC, SVHC
Power Source
AC
300 Watt
Power Consumption Stand by
0.5 Watt
Software Included
ViewSonic Wizard
31.6 cm
22.8 cm
10.37 cm
2.4 kg
Shipping Width
41 cm
Shipping Depth
45 cm
Shipping Height
22.5 cm
Limited warranty - parts and labour - 3 years , Limited warranty - lamp - 1 year
0 - 90% (non-condensing)
Sound Emission
35 dB
30 dB
