ViewSonic PJD7720HD Full HD 3200 Lumens Home Cinema Projector
Quicklinx: C3HXWS00 Mfr#: PJD7720HD
HD Format: 1080p
Aspect Ratio: 16:9
Hurry, only 2 left in stock!
£411.87 ex VAT
£494.24 inc VAT
The ViewSonic LightStream™ PJD7720HD Full HD projector features 3,200 lumens, Full HD 1920x1080 native resolution, an intuitive, user-friendly design and a sleek black chassis. Exclusive SuperColor™ technology offers a wider colour range for true-to-life image projection in any light, while SonicExpert™, ViewSonic’s proprietary sound enhancement technology, powers a 10W speaker to deliver incredibly clear and audible sound. PortAll™ - a neatly designed and enclosed HDMI/MHL connection compartment, supports wireless HDMI dongles or MHL connectors, while a cable management hood eliminates unsightly cable clutter. With a smart design, the PJD7720HD is the ideal projector for high definition presentations.
Stunning Resolution and Brightness
This projector features Full HD 1920x1080 (1080p) native resolution for the sharpest and clearest picture available. It is perfect for watching all types of high definition formats (1080p/1080i/720p) and content, including movies, videos, sports, games and TV, without any distortion or scaling of the original video format.
SuperColor™: Best-in-Class Colour Accuracy
ViewSonic’s proprietary SuperColor Technology offers a wider colour range than conventional DLP projectors. With an exclusive 6-segment colour wheel design and dynamic lamp control capabilities, SuperColor Technology projects images with reliable and true-to-life colour performance, in both bright and dark environments, without sacrificing image quality.
SonicExpert™ Technology
Following a ground-breaking proprietary speaker transducer and chamber re-design, LightStream projectors deliver full-range sound 20Hz – 20KHz for presentations or off-the-clock home entertainment. The compact speaker takes pride in quality sound with best-fit Sound Response Curve, and high efficiency of transferring electric power to sound power. SonicMode The exclusive SonicMode sound settings deliver optimized audio performance for presentations, video clips and music.
PortAll™: Discreet Wireless Streaming
This projector includes ViewSonic’s exclusive PortAll feature—a hidden compartment with an integrated and secure MHL/HDMI port that lets you discreetly stream multimedia content from a wireless dongle, or lets you connect to other devices via an HDMI cable.
Smart Design
The cable management hood connects onto the back of the projector to hide unsightly cable clutter and exposed ports. An easy-access top lamp door enables simple lamp maintenance and replacement.
Dual 3D Blu-ray Ready HDMI Inputs
Designed with two HDMI ports, this projector is perfect for connecting to any HDMI-enabled device, and can display 3D images directly from 3D Blu-ray players. 3D images can be viewed with optional ViewSonic PGD-350 Shutter Glasses, or any other compatible 3D glasses.
  • Stunning resolution and brightness
  • SuperColor - best-in-class color accuracy
    ViewSonic's proprietary SuperColor Technology offers a wider color range than conventional DLP projectors. With an exclusive 6-segment color wheel design and dynamic lamp control capabilities, SuperColor Technology projects images with reliable and true-to-life color performance, in both bright and dark environments, without sacrificing image quality.
  • SonicExpert technology
    Following a ground-breaking proprietary speaker transducer and chamber re-design, LightStream projectors deliver full-range sound 20Hz - 20KHz for presentations or off-the-clock home entertainment. The compact speaker takes pride in quality sound with best-fit Sound Response Curve, and high efficiency of transferring electric power to sound power. The exclusive SonicMode sound settings deliver optimized audio performance for presentations, video clips and music.
  • PortAll - discreet wireless streaming
    This projector includes ViewSonic's exclusive PortAll feature - a hidden compartment with an integrated and secure MHL/HDMI port that lets you discreetly stream multimedia content from a wireless dongle, or lets you connect to other devices via an HDMI cable.
  • Smart design
  • Dual 3D Blu-ray ready HDMI inputs
  • Balanced color and brightness
    A choice of 5 unique view settings provide the best possible viewing experience in any environment regardless of ambient light.
ViewSonic LightStream PJD7720HD - DLP projector - 3D
DLP projector - 1080p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Europe
Microdisplay
DMD Chip
Brightness
3200 lumens
Contrast Ratio
22000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Colour Support
1.07 billion colours
Bulb type
210 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Speakers
Speaker(s) - integrated
Environmental Standards
TCO Certified
330 Watt
31.6 cm x 22.8 cm x 10.37 cm
2.4 kg
3-year warranty
3D Capable
Built-in Devices
Speaker
Europe
Projector
Microdisplay
DMD Chip
Brightness
3200 lumens
Contrast Ratio
22000:1 (dynamic)
Image Size
76 cm - 762 cm
Throw Ratio
1.49 - 1.64:1
Digital Zoom Factor
2x
Resolution
Full HD - Full HD (1920 x 1080)
Colour Support
Bulb type
210 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
DLP 3D Ready, ViewMatch, Super Color, SonicExpert, PortAll
Lens
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
Video Interfaces
HDMI, MHL
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - mini-USB Type B , 1 x microphone - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x HDMI - 19 pin HDMI Type A
Wireless remote control
Power Source
AC
Nominal Voltage
330 Watt
Power Consumption Stand by
0.5 Watt
31.6 cm
22.8 cm
10.37 cm
2.4 kg
Limited warranty - parts and labour - 3 years , Limited warranty - lamp - 1 year
10 - 90% (non-condensing)
Sound Emission
35 dB
30 dB
HD Format: 1080p
Aspect Ratio: 16:9
Brand: ViewSonic
Price Range Ex VAT: 300 - 500
