ViewSonic PJD6241 XGA DLP Projector
Quicklinx: 758JWS00 Mfr#: PJD6241
The PJD6241 is the lightweight BrilliantColor projector that is a feature-rich performer delivering more vibrant colors and crisp, sharp images. With support for 120Hz frame rates, this high brightness projecter is ready for 3D business, education or gaming applications. Remotely manage and schedule your projector through the RJ-45 network control. Deliver a truly dynamic multimedia experience with the extensive input options, including two RGB inputs and one RGB output, and integrated 2x5-watt stereo speakers. Using less than 1 watt of power in standby mode, the PJD6241 is environmentally friendly as well. The conveniently placed lamp access and filter-free makes maintenance a breeze. Mount the PJD6241 on the ceiling for use in classrooms or meeting rooms.
  • BrilliantColor technology
    BrilliantColor technology delivers stunning all-digital clarity with life-like color, sharp graphics and outstanding video. The sophisticated 6-segment color wheel enriches the yellow color performance that is key to accurate and vivid color reproduction.
  • Closed captioning
    Integrated closed captioning decoder for the hearing impaired.
  • DLP technology
    Stunning all digital clarity delivers lifelike color, sharp graphics, and outstanding video.
  • Eco-mode extends lamp life
    Extend the life of your lamp up to 6000 hours and reduce noise output.
  • Network control through RJ-45
    Remotely schedule, manage and monitor the projector and its lamp status. Use the unique integrated clock to perform commands even when the host PC is powered down.
  • Off-to-Go feature
    The direct off feature allows the busy presenter to simply unplug the projector and go without waiting for the usual cool down phase. This feature also protects lamp life from sudden power blackout.
ViewSonic PJD6241 - DLP projector - 3D
DLP projector
3D Capable
Built-in Devices
Speaker
Brightness
3300 lumens
Contrast Ratio
2800:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
230 Watt
Bulb life cycle
Up to 2500 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (PAL, NTSC 4.43, NTSC 3.58)
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Video Output
RGB
Speakers
Speaker(s) - integrated
250 Watt
28 cm x 21.8 cm x 11.4 cm
2.8 kg
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Brightness
3300 lumens
Contrast Ratio
2800:1
Projection Distance
1.2 m - 12 m
Resolution
XGA - XGA (1024 x 768) (native) / 1280 x 1024 (resized)
Native Aspect Ratio
4:3
Bulb type
230 Watt
Bulb life cycle
Controls & Adjustments
Brightness, contrast, H/V position, colour balance, input select, colour temperature, keystone correction
OSD Languages
Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Japanese, Korean
Eco-Mode technology, BrilliantColor
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Type
Digital
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video
Video Modes
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
5 Watt
Speakers
2 x right / left channel
Input Device
External
2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 6 pin mini-DIN (PS/2 style) , 1 x network - RJ-45 (management)
Carrying case, lens cover, wireless remote control
1 x VGA cable
Security Features
FCC Class B certified, UL, TUV GS, C-Tick, cUL, ICES-003, NOM, SASO, CB, CCC, PSB, EK, IRAM, RoHS, WEEE, GOST-R
250 Watt
Power Consumption Operational (Standby)
1 Watt
Software Included
Drivers & Utilities
28 cm
21.8 cm
11.4 cm
2.8 kg
10 - 90%
Sound Emission
34 dB
32 dB
