The PJD6241 is the lightweight BrilliantColor projector that is a feature-rich performer delivering more vibrant colors and crisp, sharp images. With support for 120Hz frame rates, this high brightness projecter is ready for 3D business, education or gaming applications. Remotely manage and schedule your projector through the RJ-45 network control. Deliver a truly dynamic multimedia experience with the extensive input options, including two RGB inputs and one RGB output, and integrated 2x5-watt stereo speakers. Using less than 1 watt of power in standby mode, the PJD6241 is environmentally friendly as well. The conveniently placed lamp access and filter-free makes maintenance a breeze. Mount the PJD6241 on the ceiling for use in classrooms or meeting rooms.
BrilliantColor technology
BrilliantColor technology delivers stunning all-digital clarity with life-like color, sharp graphics and outstanding video. The sophisticated 6-segment color wheel enriches the yellow color performance that is key to accurate and vivid color reproduction. -
Closed captioning
Integrated closed captioning decoder for the hearing impaired. -
DLP technology
Stunning all digital clarity delivers lifelike color, sharp graphics, and outstanding video. -
Eco-mode extends lamp life
Extend the life of your lamp up to 6000 hours and reduce noise output. -
Network control through RJ-45
Remotely schedule, manage and monitor the projector and its lamp status. Use the unique integrated clock to perform commands even when the host PC is powered down. -
Off-to-Go feature
The direct off feature allows the busy presenter to simply unplug the projector and go without waiting for the usual cool down phase. This feature also protects lamp life from sudden power blackout.
- ViewSonic PJD6241 - DLP projector - 3D
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
- Brightness
- 3300 lumens
- Contrast Ratio
- 2800:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- 230 Watt
- Bulb life cycle
- Up to 2500 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (PAL, NTSC 4.43, NTSC 3.58)
- Video Modes
- 480p, 720p, 1080i, 480i, 576i, 576p
- Video Output
- RGB
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 250 Watt
- 28 cm x 21.8 cm x 11.4 cm
- 2.8 kg
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 3300 lumens
- Contrast Ratio
- 2800:1
- Projection Distance
- 1.2 m - 12 m
- Resolution
- XGA - XGA (1024 x 768) (native) / 1280 x 1024 (resized)
- 4:3
- Bulb type
- 230 Watt
- Bulb life cycle
- Controls & Adjustments
- Brightness, contrast, H/V position, colour balance, input select, colour temperature, keystone correction
- OSD Languages
- Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Japanese, Korean
- Eco-Mode technology, BrilliantColor
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL, NTSC 4.43, NTSC 3.58
- Analogue video Signal
- Video Interfaces
- VGA, composite video, S-Video
- Video Modes
Video Output
- Analogue Video Signal
- RGB
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 5 Watt
- Speakers
- 2 x right / left channel
Input Device
- External
- 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 6 pin mini-DIN (PS/2 style) , 1 x network - RJ-45 (management)
- Included Accessories
- Carrying case, lens cover, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- FCC Class B certified, UL, TUV GS, C-Tick, cUL, ICES-003, NOM, SASO, CB, CCC, PSB, EK, IRAM, RoHS, WEEE, GOST-R
- Voltage Required
- 250 Watt
- Power Consumption Operational (Standby)
- 1 Watt
- Software Included
- Drivers & Utilities
- 28 cm
- 21.8 cm
- 11.4 cm
- 2.8 kg
- 0 °C
- 40 °C
- 10 - 90%
- Sound Emission
- 34 dB
- Sound Emission (Economic Mode)
- 32 dB
