The LightStream PJD5253 makes a big statement with its elegant style and price defying audiovisual performance. Its curvaceous design, which includes a tactile keypad and non-slip foot pads, also presents an intuitive and user-friendly interface. Exclusive SuperColor and SonicExpert technologies provide the optimal visual and audio performance. The PJD5253 boasts a 3,200-lumen lamp with a 15,000:1 contrast ratio, delivering clear and bright images for small to medium meeting rooms or classrooms. Supporting 2x VGA, Composite Video, S-Video, and 1x VGA output, as well as Audio in/out, Mini USB and RS232, this projector has flexible connectivity with analog-based equipment. DynamicEco further reduces power consumption and extends the lamp life significantly.
Premium curved design with intuitive keypad
With its matte finish and curved edges, this LightStream Projector stands out from the competition. A tactile keypad provides ease of use with raised and concave buttons, plus a central reference button. These assist in making set up easier in dark environments or if the projector is ceiling mounted. -
SuperColor accuracy
ViewSonic's exclusive SuperColor technology delivers superior color range, ensuring that users enjoy more realistic and accurate colors. With an exclusive color wheel design and dynamic lamp control capabilities, SuperColor technology projects images with true-to-life color performance in all scenarios, also reducing eye fatigue in bright and dark images. -
SonicExpert clear, comfortable and louder sound
Following groundbreaking and exclusive speaker developments - transducer and chamber re-design - LightStream projectors deliver superior audio performance than competitor projectors. The compact yet powerful speakers sound stronger and enable sound to travel further, powerful enough to fill your meeting room with wall-to-wall sound. -
Bright images for any environment
Packed with 3,200 lumens the PJD5253 is guaranteed to produce bright images in any environment - even in rooms with high ambient light. The high contrast ratio of 15,000:1 also ensures that dark and bright areas are more black and white and less gray in appearance. -
Easy-of-use pre-set color modes
Providing 5 pre-set color modes, users can choose the one to suit their material. These 5 modes are: Brightest mode for environments where extra-high brightness is required; Dynamic mode for presentations with a lot of text; Standard mode for matching PC or notebook color; ViewMatch mode for general viewing; Movie mode for watching movies with better saturation in a dark environments. -
Quickly access your favorite features with "My Button"
Finding a function through the on-screen menu can be time-consuming. The "My Button" key on the remote control is a programmable shortcut button that can be user-programmed to launch any desired function. -
Auto Power On / Off
With Auto Power On enabled, once a VGA cable is connected and signal detected, LightStream projectors will power on automatically with effortless start-up. When no signal is detected, the projector will automatically power off after a user-defined amount of time - saving electricity cost, reducing energy consumption and extending the life of the projector.
- ViewSonic LightStream PJD5253 - DLP projector - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Localisation
- Europe
- Microdisplay
- DMD Chip
- Contrast Ratio
- 2400:1 / 15000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 190 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode ¦ Up to 10000 hour(s) - economic mode
- Video Input
- S-Video, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 265 Watt
- 31.6 cm x 22.8 cm x 10.37 cm
- 2.1 kg
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
- Localisation
- Europe
Projector
- Microdisplay
- DMD Chip
- Brightness
- 3200 lumens
- Contrast Ratio
- Image Size
- 76.2 cm - 762 cm
- Projection Distance
- 1 m - 8 m
- Throw Ratio
- 1.86 - 2.04:1
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 102 kHz
- Bulb type
- 190 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- ViewMatch, Super Color, DynamicEco Mode, Auto Power Off, auto power on, SonicExpert
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 2x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, component video, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x remote control - 9 pin D-Sub (DB-9) (management) , 1 x USB - mini-USB Type B
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable - 1.8 m
- Security Features
- UL, TUV GS, C-Tick, cUL, ICES-003, SASO, TUV S, CB, CCC, EMC, DOC, PSB, FCC, RoHS, KCC, WEEE, REACH, UkrSEPRO, KC, ERP, EAC, SVHC, CoC
- Power Source
- AC
- Voltage Required
- 265 Watt
- Power Consumption Stand by
- 0.5 Watt
- Software Included
- ViewSonic Wizard
- 31.6 cm
- 22.8 cm
- 10.37 cm
- 2.1 kg
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Sound Emission
- 34 dB
- Sound Emission (Economic Mode)
- 29 dB
