The ViewSonic LightStream Projector PJD5250 is the ultimate price-performance projector, integrating elegant style and intuitive design, VGA connectivity and best in class color performance thanks to exclusive SuperColor technology. The PJD5250 is equipped with 3,100 lumens brightness, a 6-segment color wheel, high resolution 4:3 (XGA 1024 x 768) and 18,000:1 contrast ratio for great image quality even in spaces with high ambient light. Eco mode further reduces power consumption by up to 70% and extends the lamp life up to 10,000 hours.
Premium curved design with intuitive keypad
With its dot texture finish and curved edges, this LightStream Projector stands out from the competition. A tactile keypad provides ease of use with raised and concave buttons, plus a central reference button. These assist in making set up easier in dark environments or if the projector is ceiling mounted. -
Best in class color accuracy
ViewSonic's exclusive SuperColor Technology offers a wider color range than conventional projectors for true-to-life color performance in any light. SuperColor 6-Segment Color Wheel maximizes brightness with the highest color saturation over others in the same class. -
Bright images for any environment
Packed with 3,100 lumens the PJD5250 is guaranteed to produce bright images in any environment - even in rooms with high ambient light. An impressive 18,000:1 contrast ratio also ensures that dark and bright areas are more black and white and less gray in appearance. -
Easy-of-use pre-set color modes
Providing 5 pre-set color modes, users can choose the best one to suit their material. These 5 modes are: Brightest Mode for environments where extra-high brightness is required; Dynamic Mode for presentations with a lot of text; Standard Mode for matching PC or notebook color; ViewMatch Mode for general viewing; Movie Mode for watching movies with better saturation in a dark environments. -
Quickly access your favorite features with "my button"
Finding a function through the on-screen menu can be time-consuming. The "My Button" button on the remote control is a programmable shortcut button that can be user-programmed to launch any desired function. -
Keystone distorted image correction
The PJD5250 can correct and adjust vertical distorted images into a more symmetric shape.
- ViewSonic LightStream PJD5250 - DLP projector - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Localisation
- Europe
- Brightness
- 3100 ANSI lumens
- Contrast Ratio
- 18000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- Component video
- Power
- AC 120/230 V (50/60 Hz)
- 260 Watt
- 31.6 cm x 22.8 cm x 10.37 cm
- 2.1 kg
- DLP projector
- 3D Capable
- Localisation
- Europe
Projector
- Brightness
- 3100 ANSI lumens
- Contrast Ratio
- 18000:1 (dynamic)
- Image Size
- 76.2 cm - 762 cm
- Throw Ratio
- 1.86 - 2.04:1
- Digital Zoom Factor
- 2x
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean, Indic (Indian Languages)
- DLP 3D Ready, Super Color, DynamicEco Mode, Auto Power Off, Presentation Timer, auto power on, sleep timer, My Button
Lens
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- Analogue video Signal
- Component video
- Video Interfaces
- VGA
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - mini-USB Type B
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar, keypad lock
- Power Source
- AC
- Voltage Required
- 260 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.6 cm
- 22.8 cm
- 10.37 cm
- 2.1 kg
- Sound Emission
- 32 dB
- Sound Emission (Economic Mode)
- 27 dB
