Product
ViewSonic LightStream PRO7827HD 1920x1080 Full HD 2200 Lumens Projecto
Quicklinx: C3J1WS00 Mfr#: PRO7827HD
HD Format: 1080p
Aspect Ratio: 16:9
£559.93 ex VAT
£671.91 inc VAT
Offering incredible color accuracy and stunning, razor-sharp images, the ViewSonic LightStream Pro7827HD is the ideal projector for home entertainment. Featuring Full HD 1080p resolution and ViewSonic's SuperColor RGBRGB technology, this projector delivers incredible detail and brilliantly smooth color gradients for true-to-life image projection. Designed with sRGB/Rec. 709 cinematic colors, ISF certified day and night modes, as well as a unique movie mode, the Pro7827HD delivers optimized color for a true cinema experience. SonicExpert, ViewSonic's proprietary sound enhancement technology, powers a 10W speaker to deliver incredibly clear and audible sound. The Pro7827HD also features a hidden HDMI/MHL connector with 5V USB power, whicokh is perfect for media streaming dongles. With a shorter throw ratio, vertical lens shift, 1.3x optical zoom, smart design, and extensive connectivity, the Pro7827HD provides flexible and quick set-up in any home.
  • Full HD 1080p for the finest picture quality
    This projector features Full HD 1920x1080 (1080p) native resolution for the sharpest and clearest picture available, 144Hz 3D frame rate for smoother images and better 3D perception and DarkChip3 for deep blacks, finer pixels and exceptionally smooth motion. It is perfect for watching all types of high definition formats (1080p/1080i/720p) and content, including movies, videos, sports, games, and TV, without any distortion or scaling of the original video format.
  • Cinema SuperColor RGBRGB color wheel for true-to-life color
    The Cinema SuperColor RGBRGB Color Wheel adopts a special coating to filter segmental spectrums of RGB, to intensify Red, Blue, and Green colors. It fulfils sRGB and Rec. 709 standards, and features pure colors to increase visual performance, especially for Blu-ray DVDs. It also focuses on Hue and Saturation enhancement, highlighting breath-taking images like sunrises, sunsets, or blue skies with intense color gradients, while other projectors can only partially cover these complex color gradients.
  • Superior performance with DarkChip3 from Oscar award winning TI DLP DMD display technology
    DLP display technology combines accurate, long lasting color with high native contrast ratios. In particular, DLP utilizes "True Black", which improves projection accuracy, creating razor-sharp images for cinema, unlike other well-known technology projectors that use dark gray instead of "True Black" because of limited technology. DarkChip3 DMD is designed for high-definition video rendering to enhance contrast levels, creating extreme blacks and brilliant whites on the projected screen.
  • ISF certified color calibration tools
    ISF (Imaging Science Research Lab) Certified for customized color calibration, this projector provides the calibration tools to allow ISF-certified technicians to provide on-site tuning of Day and Night modes. The customized fine-tuned mechanism will become the default option to fit each user's scenario requirement in bright and dark environments.
  • SonicExpert technology for clear, comfortable, and louder sound
    Following a ground-breaking proprietary speaker transducer and chamber re-design, LightStream projectors deliver full-range sound 20Hz - 20KHz for presentations or off-the-clock home entertainment. The compact speaker takes pride in quality sound with best-fit Sound Response Curve, and high efficiency of transferring electric power to sound power. SonicMode The exclusive SonicMode sound settings deliver optimized audio performance for presentations, video clips and music.
  • Easy image adjustment with complete keystone
    Horizontal and vertical keystone correction, as well as a 4 corner adjustment feature eliminates crooked and distorted images for a perfectly proportioned picture every time. A 1.3x optical zoom lens provides mounting flexibility with a wider throw distance range while a 1.1 - 1.5 shorter throw ratio projects large images from short distances in small rooms.
  • Smart design
    The cable management hood connects onto the back of the projector to hide unsightly cable clutter and exposed ports. An easy-access top lamp door enables simple lamp maintenance and replacement. The tactile keypad is raised with concave buttons that assist in making projector set up easier in dark environments.
ViewSonic LightStream Pro7827HD - DLP projector - portable - 3D
DLP projector - 1080p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Keypad
Bundled Services
1 year Express Exchange Service
Americas
Brightness
2200 ANSI lumens
Contrast Ratio
22000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours (30-bit)
Lens
Zoom lens
Lens Shift Direction
Vertical
Bulb type
240 Watt
Bulb life cycle
Up to 3500 hours - normal mode , Up to 6500 hours - economic mode
Video Input
RGB, S-Video, composite video
Video Modes
1080p
Speakers
Speaker(s) - integrated
350 Watt
31.6 cm x 22.8 cm x 10.37 cm
2.6 kg
3 years warranty
3D Capable
Built-in Devices
Keypad
Bundled Services
Americas
Projector
Brightness
2200 ANSI lumens
Contrast Ratio
22000:1 (dynamic)
Image Size
76 cm - 762 cm
Projection Distance
1.29 m - 14.28 m
Throw Ratio
1.1 - 1.5:1
Resolution
Full HD - Full HD (1920 x 1080) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
240 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction, zoom, focus, lens shift dial (vertical)
Rec. 709 Mode, MHL compliance, SonicExpert, ISF (Imaging Science Foundation), PortAll, ViewSonic SuperColor TruCinema, ISF Night/Day
Lens
Zoom lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.3x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Vertical
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
Video Modes
1080p
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - mini-USB Type B , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x HDMI input - 19 pin HDMI Type A
Cable cover, wireless remote control
1 x VGA cable
Security Features
Security Slot Type
Kensington security slot
C-Tick, NOM, TUV S, CB, CCC, FCC, RoHS, WEEE, cTUVus, REACH, ERP, CECP, EAC, SVHC
Power Source
AC
Nominal Voltage
350 Watt
Power Consumption Stand by
0.5 Watt
Software Included
ViewSonic Wizard
31.6 cm
22.8 cm
10.37 cm
2.6 kg
Shipping Width
41 cm
Shipping Depth
45 cm
Shipping Height
22.5 cm
Shipping Weight
5.3 kg
Limited warranty - parts and labour - 3 years , Limited warranty - lamp - 1 year
0 - 90% (non-condensing)
Sound Emission
34 dB
31 dB
HD Format: 1080p
Aspect Ratio: 16:9
Brand: ViewSonic
Price Range Ex VAT: 500 - 750
