The ViewSonic EP1031r is a 10.1" wall-mounted multimedia all-in-one electronic mini billboard. It delivers eye-catching commercial messaging at retail POS, hotel lobbies and front desks, conference and exhibition venues, and other high-visibility locations. The EP1031r features wireless b/g/n network and LAN connectivity for easy loading of content, and supports Power over Ethernet (PoE) for convenient one-wire installation. The EP1031r effectively delivers customized messaging to target audiences. Its built-in media player, internal storage, and integrated speakers enable the playback of video clips, as well as photos and music, from a USB hard drive or SD/SDHC memory card. With VESA-mount compliance, and W3C and SMIL compatibility, the EP1031r provides versatile options for creative brand messaging.
Perfect size for up-close, high-impact messaging
ViewSonic's EP1031r all-in-one electronic mini billboard has a 10.1" display area with 800 x 480 resolution. With its compact design, the EP1031r can be deployed anywhere, including retail shelf edges, hotel front desks, in meeting rooms, or on classroom doors. The EP1031r features 300-nit brightness and a 500:1 contrast ratio to deliver high-impact, quality messaging that will attract the attention of passersby. -
Advanced motion sensor and 6 programmable touch keys
Equipped with an advanced motion sensor, the EP1031r can display customized content whenever movements of nearby people are detected. And with 6 highly visible and easy-to-use programmable touch keys, users can directly interact with brand offerings and retail messaging. -
Convenient one-wire installation via Power over Ethernet
The EP1031r utilizes state-of-the-art Power over Ethernet (PoE) technology for one-wire installation. This allows you to easily power and connect your displays with just a single cable. PoE also allows you to create multi-display digital signage installations, while reducing installation costs. -
Easy loading of content through wireless/RJ45 Ethernet
The EP1031r integrates wireless 802.11 b/g/n network and RJ45 Ethernet connectivity, providing a convenient and efficient way to load content from a PC or laptop connection. Wireless/LAN connectivity can also be used to remotely load content to multiple displays. -
USB multimedia player for scheduled playback of videos, photos and music
With the handy PC-less USB playback feature, photos, music and 1080p video can be immediately displayed on-screen from a USB drive. A user-friendly on-screen scheduling interface also lets you select time, date, repeat and shuffle settings, or choose specific content to play from the attached USB source. It's easy and efficient. -
Built-in speakers that really speak to your audience
Integrated with a pair of stereo 2 W speakers, the EP1031r combines eye-catching multimedia content with high-quality sound effects - creating an incredible audio-visual impression on your target audience.
- ViewSonic EP1031r 10.1" LED-backlit LCD display - for interactive communication
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 10.1"
- Commercial Use
- Yes - interactive
- Black
- Resolution
- 800 x 480
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- Connectivity
- Wi-Fi, LAN
- LCD Backlight Technology
- LED backlight
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Supported Memory Cards
- SD Memory Card, SDHC Memory Card
- USB
- 2 ports
- Included Accessories
- Signage Manager Express software
- Voltage
- AC 120/230 V (50/60 Hz)
- 12 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 27.8 cm x 4 cm x 18.6 cm
- 2.1 kg
- Product Type
- 12 Watt
- Diagonal Class
- 10.1"
- Commercial Use
- Yes - interactive
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Motion sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- Dimensions
- Without stand
- 27.8 cm
- 4 cm
- 18.6 cm
- 2.1 kg
- Enclosure Colour
- Black
Display
- Resolution
- 800 x 480
- LED backlight
- Coating
- Anti-glare
- Image Contrast Ratio
- 500:1
- Brightness
- 300 cd/m²
- Viewing Angle
- 170 degrees
- Viewing Angle (Vertical)
- 160 degrees
- Response Time
- 30 ms
- Backlight Life
- 50,000 hour(s)
- Security lock slot (cable lock sold separately), Synchronized Multimedia Integration Language (SMIL)
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 75 x 75 mm
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, WMV
- Supported Audio Formats
- MP3
- Supported Pictures Formats
- JPG, PNG
- USB Port
- USB Ports Qty
- 2
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 4 Watt
- Speakers
- 2 x speaker - 2 Watt
Network & Internet Multimedia
- Connectivity
- Wi-Fi, LAN
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11b, 802.11g, 802.11n
- Connector Type
- 2 x USB 2.0 , HDMI , Audio line-out , LAN , USB 2.0
- Cables Included
- Network cable , Mini-phone 3.5 mm to 2 x RCA adapter
- FCC
- Power Device
- Power adapter
- Input Voltage
- 0.5 Watt
- 0 °C
- 40 °C
- 5 - 85% (non-condensing)
