ViewSonic CDP4635 46" Slim Bezel Full HD 1080p Intel® OPS Ready LCD Commercial Display
Quicklinx: 9CZWWS00 Mfr#: CDP4635
  • 1080p
The 46" CDP4635 is full high-definition commercial display, boosting 1920 x 1080 resolution. The units are video wall-ready with up to 5 x 5 tiling function, and the adjustable bezel adds easy touch panel integration. Multiple video inputs, including HDMI, DVI, VGA and CVBS are included, and the VGA and CVB inputs allow up to nine units to be displayed through one video source. The display's OPS slot ensures easy installation of any OPS compatible media player.
ViewSonic CDP4635 46" LCD flat panel display - Full HD
Diagonal Class
46"
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
480p, 720p, 1080i, 1080p, 480i
Max Number of Screens
25
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
Image Aspect Ratio
16:9
TV Tuner
No tuner
Sound Output Mode
Stereo
Speaker System
2 speakers, amplifier
Remote control
Voltage
AC 120/230 V (50 - 60 Hz)
270 Watt
109 cm x 12 cm x 64.6 cm
24.6 kg
270 Watt
Diagonal Class
46"
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
Dimensions
Without stand
109 cm
12 cm
64.6 cm
24.6 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Colour Depth
16.7 million colours
Image Contrast Ratio
4000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.53025 x 0.53025mm
Video Wall
25
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 200 mm, 400 x 400 mm
Video Features
Input Video Formats
Remote Control
Remote control
Audio System
Sound Output Mode
Stereo
Speaker System
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
Serial input , Serial output , LAN , VGA input , VGA output , DVI-D input , HDMI , Component video input , S-Video input , Composite video input , Composite video output , Audio input , 2 x audio input , Audio output , 2 x speakers output
Expansion Slots
1 x Expansion Slot
Input Voltage
Power Consumption Stand by / Sleep
1 Watt
Dimensions & Weight Details
Panel without stand - 109 cm x 12 cm x 64.6 cm x 24.6 kg , Panel with stand - 109 cm x 33 cm x 68.2 cm x 26.3 kg
20 - 80% (non-condensing)
