ViewSonic CDE6560T 65" Full HD interactive LED display solution is perfect for business and education. This 10-point touch-enabled display, paired with pre-installed annotation software, allows multiple users to simultaneously write or draw on the display's hardness surface using fingers or stylus. A Full HD screen guarantees crisp and vivid image quality, while 360-nit brightness and wide viewing angles provide better visual performance in well-lit rooms. With built-in dual core processor and 8GB internal storage, as well as integrated versatile connectivity including HDMI, VGA, YPbPr, RS232, RJ45 and USB ports, this display provides powerful computing for annotation and multimedia playback without the need for a PC. The CDE6560T is VESA mountable (wall mount kit WMK-047 included for Europe region) or choose the optional trolley cart for flexible installation for classrooms and corporate meeting rooms.
10 point touch interactive capabilities for collaboration with multiple users
With 10-point simultaneous touch technology, the CDE6560T encourages group interaction. Multiple users can simultaneously write or draw on this larger-sized display's 7H hardness surface using styluses or their fingers - or both at the same time! And its superior touch report rate provides a smoother user touch experience for both educational and corporate applications. -
Easy for presentation without the needs of PCs
Equipped with a powerful dual-core processor, the CDE6560T provides smooth and fast computing for todays demanding applications. This large format display is able to playback presentation files and multimedia contents directly from onboard 8GB memory, USB drive, and even surf the Internet via the LAN connection. -
Superior screen performance enhances presentation quality
This large format display features a 1920 x 1080 resolution, 360 nits brightness and 4000:1 contrast ratio, delivering sharp and crisp image performance for in-door environment. The display also features wide viewing angles, delivering true and consistent color performance and ensures the audiences at the corners in the boardroom and classroom can see the presentation files clearly. -
Eye-Care technologies create comfort viewing environment
The CDE6560T adopts exclusive Flicker-free and Blue Light Filter eye-care technologies. By nearly eliminating screen flickering at all brightness levels by providing a constant LED light source and reduce blue light exposure, the display ensures longer viewing time and increase eye comfort for presentation and multimedia experience - without eye fatigue. -
RS232 connectivity for easy multi-device management
RS232 connectivity enables computers and laptops to be connected to the CDE6560T. RS232 connectivity also allows IT personnel to conveniently manage multiple displays, configure devices, and upgrade firmware from a centralized location. This provides organizations the ability to better maintain and control large numbers of displays from a single location. -
Protective ID design ensures durability
A rounded-corner design provides a safer learning environment for active students by helping to prevent injuries in the classroom and it features 7H scratch-resistant surface hardness that ensures durability, as well as a consistent, high-quality touch experience. In addition, an anti-glare film improves screen visibility in bright environments. -
Energy-saving LED backlight
The CDE6560T utilizes an energy-saving LED backlight that consumes 35% less power than conventional CCFL backlight displays. This provides for a lower overall cost of ownership, along with a higher ROI, making this display a great long-term investment.
- ViewSonic CDE6560T 65" Class (64.5" viewable) LED-backlit LCD display - Full HD - for interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 65"
- Diagonal Size
- 64.5"
- Commercial Use
- Yes - interactive
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 480p, 720p, 1080p, 480i
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 3 ports
- Connectivity
- LAN
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- TV Tuner
- No tuner
- Picture Enhancements
- Blue Light Filter
- Speaker System
- 2 speakers
- Storage Capacity
- 8 GB Flash
- USB
- 4 ports
- Included Accessories
- Remote control, 3 styluses, ViewSonic WMK-047 wall mount kit
- Voltage
- AC 100/240 V (50/60 Hz)
- 270 Watt
- Power Consumption Stand by
- 0.5 Watt
- 154.5 cm x 9.6 cm x 93.7 cm
- 69 kg
- Product Type
- 270 Watt
- Diagonal Class
- 65"
- Diagonal Size
- 64.5"
- Commercial Use
- Yes - interactive
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Blue Light Filter
- Protection
- Anti-scratch display
- 154.5 cm
- 9.6 cm
- 93.7 cm
- 69 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- LED backlight
- Coating
- Anti-glare, 7H Hard
- Colour Depth
- 10-bit colour
- Image Contrast Ratio
- 4000:1
- Brightness
- 360 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 10
- Response Time
- 8 ms
- Backlight Life
- 50,000 hour(s)
- Colour Temperature Control
- Eye Care, infrared multitouch technology, Flicker free technology
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Video Features
Media Player
- USB Port
- USB Ports Qty
- 4
- Configuration
- ARM Cortex-A9 Dual-Core - 1.5 GB DDR3 - 8 GB Flash - Mali 400
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- LAN Protocol
- Gigabit Ethernet
- Connector Type
- 3 x USB 2.0 , USB 3.0 , USB , 3 x HDMI input , 3 x VGA input , 3 x audio line-in , Composite video input , Digital audio output (optical) , LAN , VGA output , Serial input , Headphones
- 3 styluses, ViewSonic WMK-047 wall mount kit
- Cables Included
- VGA cable , USB cable , Audio cable , Serial adapter
- EAC, EEI
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Width (Shipping)
- 171.5 cm
- Depth (Shipping)
- 28 cm
- Height (Shipping)
- 108.5 cm
- Weight (Shipping)
- 80 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
