The ViewSonic CDE3203 is a great value, high performance 32" Full HD LED commercial display for hotel, restaurant and hospitality environments. In addition to versatile connectivity options, including HDMI, VGA, and SPDIF, the display comes with a simple and convenient USB multimedia playback functionality. With 1920 x 1080 resolution, 350-nit brightness, wide viewing angles and dual 10W stereo speakers, the slim-bezel CDE3203 delivers vivid images and remarkable sound for superior multimedia performance. The HDMI CEC pass-through support provides one-touch-play, with additional features for multiple connected devices such as HD set-top-boxes, media players, and Blu-ray players. An RS232 port with IR pass-through provides automated control for hospitality installation. Creating a more comfortable viewing experience, the display is equipped with Flicker-Free and Blue Light Filter technologies. In addition, free-bundled vController software offers easy maintenance and intuitive interfaces for remote management via a PC server or laptop.
Integrated USB multimedia player
This display features an integrated media player with a convenient USB playback function. Now photos, music, and 1080p video can be quickly displayed on-screen directly from a USB drive - without the need for a PC. -
Hospitality mode
This display is great for multi-screen setups in hotels, restaurants, sports bars, or retail outlets that require automated control and customizable presets. With a USB-programmable hospitality setting, each display will have the same customized channel default, audio level, front-panel lockout, and auto power-up settings. -
Control multiple devices
RS232 IR pass-through offers local control for set-top boxes, and other RS232 connected devices, directly with the display's remote controller. HDMI CEC functionality offers local control of DVD players, sound systems, and other HDMI connected devices, directly with the display's remote controller. -
Enhanced viewing comfort
Flicker-Free technology and a Blue Light Filter help to eliminate eye strain from extended viewing periods. -
Dual integrated speakers
Designed with dual integrated speakers, this display combines incredible screen performance with stereo sound for an immersive multimedia experience. An additional speaker can be added via the SPDIF audio-out port for expanding sound to different locations in the room or venue, via cable.
- ViewSonic CDE3203 32" Class (31.5" viewable) LED-backlit LCD display - Full HD - for digital signage / hospitality
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- Yes - digital signage / hospitality
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 480p, 720p, 1080i, 1080p, 480i
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), Mobile High-Definition Link (MHL)
- LCD Backlight Technology
- WLED backlight
- Image Aspect Ratio
- 16:9
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, 2 AAA batteries
- Voltage
- AC 100/240 V (50/60 Hz)
- 68 Watt
- Power Consumption (On mode)
- 41 W
- Dimensions (WxDxH) - without stand
- 72.9 cm x 4.85 cm x 42.97 cm
- 5.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- 68 Watt
- 41 W
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- Dimensions
- Without stand
- 72.9 cm
- 4.85 cm
- 42.97 cm
- 5.3 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- WLED backlight
- Coating
- Anti-glare, hard
- Image Contrast Ratio
- 1200:1
- Brightness
- 320 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Backlight Life
- 30,000 hours
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 100 x 200 mm
Video Features
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Digital Audio Format
- Dolby Digital output
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Balance control
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- MHL/HDMI input - rear , HDMI input - side , DVI-D input - rear , VGA input - side , Audio input - side , USB - side , Serial - side , Remote control output - side , Composite video / component video input - rear , Audio input - rear , SPDIF output - rear , Headphones - rear
- 2 AAA batteries
- CB, FCC, cTUVus, CoC
Sustainability Information
- ENERGY STAR Certified
- Power Device
- Power adapter
- Input Voltage
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 72.9 cm x 4.85 cm x 42.97 cm x 5.3 kg , Panel with stand - 79.6 cm x 16.43 cm x 46.57 cm x 7.4 kg
- Width (Shipping)
- 79.6 cm
- Depth (Shipping)
- 12.1 cm
- Height (Shipping)
- 50.4 cm
- Weight (Shipping)
- 7.2 kg
- 0 °C
- 40 °C
- 15 - 90% (non-condensing)
