Verbatim Datalife 48/52x Spindle 100PK
Customer rating: 4.0* (Write a review)
Quicklinx: 3Q3RWS00 Mfr#: 43411
Media Type: CD-R
Max Speed: 52x
Pack Size: 100
Capacity: 700MB
More than 50 In Stock
£18.52 ex VAT
£22.22 inc VAT
CD-R is short for "CD-Recordable". The discs are also known as WORM media, which stands for Write Once, Read Multiple. The advantage of CD-R over other types of optical media is that you can use the discs with a standard CD player. A related technology called CD-Rewritable (CD-RW) allows you to erase discs and reuse them, but the CD-RW media does not necessarily work in all players as technology has changed since certain models were brought out. The mechanical specifications of Verbatim media are very precise, and data written to it can be read in a wide range of drives.
  • Ideal for media
    Due to the extensive research and development undertaken over the past decades, Verbatim is able to provide high-quality discs, ensuring that all your data will be safely stored and will last a lifetime.
  • Long lifetime
    Optical discs provide a great solution for long-term safe and secure storage of your important files - ideal for all your precious photos, videos and documents that you want to keep forever. They are dust- and water-resistant and can withstand wide changes in temperature and humidity.
  • Extra protection
    The white surface on these CDs provides extra protection for the label side of the disc. This coating can be written on with a CD/ DVD marker pen.
Verbatim - CD-R x 100 - 700 MB - storage media
Storage media - CD-R
Media Included Qty
100
Native Capacity
700 MB
Recording Time
80min
Write Speed
52x (max)
Extra Protection Surface
Package Type
Spindle
CD-R
Media Included Qty
100
Max. Write Speed
52x
14.1 cm
14.1 cm
16.9 cm
1.65 kg
Media
Native Capacity
700 MB
Recording Time
80min
Archival Life
100 years
Package Type
Spindle
Customer reviews
Write a review for the Verbatim Datalife 48/52x Spindle 100PK here!
BRILLIANT
Reviewed by Anonymous Review Posted 18/03/2008
NO ERRORS - FIRST! AND VERY RELIABLE,..
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Reliable, with very few errors.
Reviewed by Anonymous Review Posted 19/09/2006
My favorite CD to be honest. I have tried the cheaper ones but they generate far too many errors. I get through about 500 CDs a month so I have plenty of bitter experience of substandard products. Now I stick with this one.
  • Overall 5*
  • Ease of use 5*
Ignore my previous review!
Reviewed by . Review Posted 11/07/2006
Ignore my previous review. My DVD drive has broken and has stopped reading CD's, although it is reading DVD's fine! I'm sure these CD's will be ok.
  • Overall 5*
  • Ease of use 5*
Read all 4 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Media Type: CD-R
Max Speed: 52x
Pack Size: 100
Capacity: 700MB
Brand: Verbatim
Stock Status: Clearance
