CD-R is short for "CD-Recordable". The discs are also known as WORM media, which stands for Write Once, Read Multiple. The advantage of CD-R over other types of optical media is that you can use the discs with a standard CD player. A related technology called CD-Rewritable (CD-RW) allows you to erase discs and reuse them, but the CD-RW media does not necessarily work in all players as technology has changed since certain models were brought out. The mechanical specifications of Verbatim media are very precise, and data written to it can be read in a wide range of drives.
Ideal for media
Due to the extensive research and development undertaken over the past decades, Verbatim is able to provide high-quality discs, ensuring that all your data will be safely stored and will last a lifetime. -
Long lifetime
Optical discs provide a great solution for long-term safe and secure storage of your important files - ideal for all your precious photos, videos and documents that you want to keep forever. They are dust- and water-resistant and can withstand wide changes in temperature and humidity. -
Extra protection
The white surface on these CDs provides extra protection for the label side of the disc. This coating can be written on with a CD/ DVD marker pen.
- Verbatim - CD-R x 100 - 700 MB - storage media
- Storage media - CD-R
- Media Included Qty
- 100
- Native Capacity
- 700 MB
- Recording Time
- 80min
- Write Speed
- 52x (max)
- Extra Protection Surface
- Package Type
- Spindle
- Limited lifetime warranty
- CD-R
- 100
- Max. Write Speed
- 52x
- 14.1 cm
- 14.1 cm
- 16.9 cm
- 1.65 kg
Media
- Native Capacity
- 700 MB
- Recording Time
- 80min
- Archival Life
- 100 years
- Package Type
- Spindle
Customer reviews
Write a review for the Verbatim Datalife 48/52x Spindle 100PK here!
BRILLIANT
Reviewed by Anonymous Review Posted 18/03/2008
NO ERRORS - FIRST! AND VERY RELIABLE,..
Overall
Ease of use
Value for money
Reliable, with very few errors.
Reviewed by Anonymous Review Posted 19/09/2006
My favorite CD to be honest. I have tried the cheaper ones but they generate far too many errors. I get through about 500 CDs a month so I have plenty of bitter experience of substandard products. Now I stick with this one.
Overall
Ease of use
Value for money
Ignore my previous review!
Reviewed by . Review Posted 11/07/2006
Ignore my previous review. My DVD drive has broken and has stopped reading CD's, although it is reading DVD's fine! I'm sure these CD's will be ok.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
