Verbatim ABS 1.75mm 1kg - Transparent
Quicklinx: BP9BWS00 Mfr#: 55015
High performance Acrylonitrile Butadiene Styrene (ABS) is a commonly used thermoplastic. It is not considered food safe. Highly durable and more flexible than PLA, it offers good heat resistance and a smooth finish. To avoid warping, a printer with a heated bed is required. The optimum operating temperature is between 230°C and 240°C on most printers.
Verbatim - transparent - ABS filament
ABS filament
Filament Diameter
1.75 mm
1 kg
Printing Technology
FDM
Printing Colour
Transparent
Consumable
Consumable Type
ABS filament
Filament Diameter
1.75 mm
1 kg
Printing Technology
FDM
Transparent
Nozzle Temperature
240 °C
