Verbatim 8GB PinStripe USB Drive Black
Quicklinx: 71X7WS00 Mfr#: 49062
With USB ports in almost every computer and popping up in cars, DVD and multimedia players, TVs, photo frames and more, USB drives are now being considered an essential accessory.
The Store 'n' Go PinStripe USB drive from Verbatim has a push and pull sliding feature which protects the USB connection when it is not in use without the need for a separate cap which is easily lost.
This USB flash drive comes in paper blister package.
  • Everyday storage
    Ideal for storing and transferring files for work or for play.
  • Easy to use
    Just plug into any USB-A port and drag and drop your folders and files.
  • Protected connector
    The push and pull sliding feature protects the USB connection when it is not in use. No need for a separate cap which can be easily lost.
Verbatim PinStripe USB Drive - USB flash drive - 8 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
8 GB
Enclosure Colour
Linux 2.4.0 or later, Apple MacOS 9.0.x or later, Microsoft Windows Vista / XP / 7 / 8
Microsoft Certification
Certified for Windows Vista
USB flash drive
Storage Capacity
8 GB
Enclosure Colour
Read Rate
Up to 8 MB/s
Write Rate
Up to 2.5 MB/s
Interface Type
USB 2.0
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Limited warranty - lifetime
54 mm
21 mm
9.2 mm
8.6 g
