Enjoy up to 24 hours of uninterrupted wireless music from a single charge, with the ZB-6 on-ear headphones from the Veho Z-Series audio range.
The Veho ZB-6’s feature low energy 4.1 Bluetooth connectivity, ideal for connecting up wirelessly to the Apple iPhone 7, iPhone 7 Plus, Android Smartphones or other Bluetooth devices such as, PC’s, tablets and MP3 players.
The 40mm acoustic drivers deliver a premium audio quality, with well-balanced mids and high fidelity treble, producing an enhanced listening experience. The Veho ZB-6’s also feature noise isolating technology, which means they’re are ideal for commuting, watching movies, the gym or for general everyday use.
Take voice calls and control your music’s track selection or volume thanks to the built-in microphone and remote control on the ear-cups. The Veho ZB-6’s also support voice commands for Siri and Google Now.
The built in 3.5mm auxiliary port make the ZB-6 headphones compatible with any standard AUX connections and will enable the ZB-6 to work as standard headphones when out of battery. The folding design makes them easy to store in your bag and allow you to take them anywhere you want.
Key Features
- Built-in rechargeable battery allowing up to 24 hours continuous music playback
- Connect via 4.1 Bluetooth for wireless listening or use optional 3.5mm aux jack
- Well balanced mids and high fidelity treble delivering a premium audio experience
- Noise isolating super soft ear cups and Tacton rubber touch for a stylish finish
- Take voice calls and control your music with the multi-function on-ear controls.
Box Contents
- Veho ZB-6 Bluetooth headphones
- 120cm auxiliary cable with 3.5mm jack
- Micro USB to USB-A charging cable
- Multi lingual user manual (English, French, Spanish, German, Italian, Portuguese, Japanese & Chinese).
- Veho ZB-6 - headphones with mic
- Product Type
- Headphones - Bluetooth - wireless
- Compatibility
- iPhone, Android phone
- Recommended Use
- Portable electronics
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Radio Frequency Range
- 2.402 - 2.480GHz
- Bluetooth Version
- Bluetooth 4.1 EDR
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 100 dB
- Impedance
- 32 Ohm
- Product Type
- Compatibility
- Recommended Use
- Max Operating Distance
- 10 m
Headphones
- On-ear
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.1 EDR
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Sensitivity
- 100 dB
- Impedance
- 32 Ohm
- Diaphragm
- 40 mm
Wireless Link
- 2.402 - 2.480GHz
- Connector Type
- Headphones (mini-phone stereo 3.5 mm)
- Cables Included
- Audio cable - 1.2 m
- Included Accessories
- Micro-USB charging cable
- Battery
- Headphone battery rechargeable - Lithium Ion
- Capacity
- 380 mAh
- Run Time (Up To)
- 24 hour(s)
- Standby Time
- 250 hours
- Recharge Time
- 3 hour(s)
