Veho ZB-5 Wireless On Ear BlueTooth Headphones
Quicklinx: CLD7WS00 Mfr#: VEP-012-ZB5
The Veho ZB-5 wireless on-ear headphones feature low energy Bluetooth connectivity, ideal for connecting up wirelessly to the Apple iPhone 7 or iPhone 7 Plus.
The lightweight design and leather finish with super soft ear cups make the ZB-5 headphones incredibly comfortable to wear for long periods.
The fold flat design makes them easy to store in your bag and allow you to take them anywhere you want.
The 50 mm acoustic drivers deliver the ZB-5's a high clarity audio quality, which when mixed together with the powerful bass, produce a better listening experience. The Veho ZB-5's are ideal for commuting, watching movies, DJ sets, and the gym or for general everyday use.
The Veho ZB-5's come with a built-in microphone and remote control, perfect for making and taking calls or for simply changing the track or volume control, without having to take out your device from your pocket or bag.
The ZB-5's also include a 3.5 mm auxiliary cable too, making these headphones compatible with any standard aux connections and will work as standard headphones when out of battery.
Veho ZB-5 - headphones with mic
Headphones - Bluetooth - wireless
Compatibility
iPhone, iPad, iPod
Recommended Use
Portable electronics, computer
Headphones Form Factor
On-ear
Foldable
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.1 EDR
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 106 dB
Impedance
32 ohm
Controls
Volume, answer/end
Compatibility
iPhone, iPad, iPod
14.5 cm
6.7 cm
18.5 cm
Recommended Use
Max Operating Distance
10 m
Audio Output
On-ear
Foldable
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.1 EDR
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
106 dB
Impedance
32 ohm
Diaphragm
50 mm
Remote Control
Controls
Volume, answer/end
Wireless Link
Transmission Range
10 m
Cable Details
Audio cable - 1.2 m , Micro-USB charge cable
Headphone battery rechargeable
400 mAh
Run Time (Up To)
19 hour(s)
Standby Time
250 hours
