Veho VFS-004 Deluxe - Film scanner (35 mm) - 35mm film - Hi-Speed USB
PRICED TO CLEAR, WAS £39.05!
Quicklinx: 7TSPWS00 Mfr#: VFS-004-DELUXE
Bring back to life those old memories on 35mm formats. The VFS-004 scanner will scan old 35mm slides and negatives to your PC, ready for printing, editing, storing or sharing.
Transfer your old 35mm negative film and slides onto your PC/Notebook ready for editing, archiving or printing. Simple and fast one touch scanning makes it easy to bring those old pictures back to life. If you want to remove redeye or enhance your image in anyway then simply use the bundled Arcsoft Photoimpression software.
Box Contents
Film scanner with USB lead attached
Slide tray
35mm Neg tray
CD Driver with application software
Lens cleaning tool
Veho VFS-004 Deluxe - film scanner (35 mm) - desktop - USB 2.0
Film scanner (35 mm) - desktop
Interface Type
USB 2.0
Max Supported Document Size
Film 135 (35mm)
Grayscale / Color Depth
48-bit colour
Supported Document Type
Film
Microsoft Windows XP, Microsoft Windows Vista (32/64 bits)
Interface Type
USB 2.0
Film 135 (35mm)
Scanner
Colour Depth
48-bit colour
Scanner Features
Powered by USB port
Media Handling
Film
