Control your MUVI K-Series camera wirelessly for distances of up to 120m (390ft) thanks to the MUVI Wi-Fi remote control from Veho. SRP $59.95
The Wi-Fi wireless remote control has a built-in lithium-ion rechargeable battery which can last up to 5 hours of continuous use when paired with your MUVI K-Series, so you can be sure that you never miss a moment.
The rugged and robust design of the Wi-Fi remote has an IP66 rating, which means that the remote is protected from total dust ingress and from high pressure water jets from any direction. Perfect for any action sports such as cycling, skiing/snowboarding, mountain climbing and other outdoor activities.
The Wi-Fi remote has 7 controlling buttons allowing you to control all the camera's settings and features, such as video recording, still photos, time-lapse recording and setting and function changes, ensuring you capture what you want.
The Wi-Fi remote has a built-in LCD screen, which when paired with your MUVI K-Series will mirror the status screen directly on the remote control, for confirmation of the cameras functions and settings. Using the wrist/body strap you can attach your wireless remote to yourself or your equipment enabling you to keep your hands free for your activity.
- Veho MUVI wireless remote control
- Accessory Type
- Wireless remote control
- Transmitters
- Radio - 120 m
- Designed For
- Muvi K-Series K-1, K-Series K-2, K-Series K-2 NPNG
- Accessory Type
Accessories
- Intended for
- Action camera
- Dustproof, built-in LCD display, splash-proof
- Wireless Interface
- Wi-Fi
Transmitters
- Radio
- Operational Range
- 120 m
Kit Content
- Kit Content
- (1) x remote control , (1) x USB cable , (1) x wrist strap
- Designed For
- Veho muvi K-Series K-1, K-Series K-2, K-Series K-2 NPNG
