Veho VCC-A035-WPC 100m Waterproof case for Muvi K-Series only
Quicklinx: BHLTWS00 Mfr#: VCC-A035-WPC
The MUVI K-Series waterproof case allows your camera to be fully functional for both filming and photography. Simply fit your camera into the waterproof case and your camera will be protected from bumps and shocks as well as waterproof down to 100 m. While fitted in the waterproof case the K-Series remains functional with 2 buttons for operation of filming and photography. The waterproof case has a standard tripod mount and a port access point for power and microphone access.
Muvi K-Series - marine case camcorder
Marine case camcorder
Underwater Depth
Up to 100 m
Underwater Use
Carrying Case
Marine case
Recommended Use
Camcorder
Protection
Waterproof, shockproof
Underwater Depth
Up to 100 m
2 waterproof backdoors
Integrated tripod mount
IP68
