The MUVI K-Series waterproof case allows your camera to be fully functional for both filming and photography. Simply fit your camera into the waterproof case and your camera will be protected from bumps and shocks as well as waterproof down to 100 m. While fitted in the waterproof case the K-Series remains functional with 2 buttons for operation of filming and photography. The waterproof case has a standard tripod mount and a port access point for power and microphone access.
- Muvi K-Series - marine case camcorder
- Product Type
- Marine case camcorder
- Underwater Depth
- Up to 100 m
- Underwater Use
Carrying Case
- Marine case
- Recommended Use
- Camcorder
- Protection
- Waterproof, shockproof
- Underwater Depth
- Up to 100 m
- Included Accessories
- 2 waterproof backdoors
- Integrated tripod mount
- IP68
