The brand new super tiny Muvi Atom redefines the world of small. Measuring less than 2 inches high it's one of the smallest camcorders in the world.
The Muvi Atom's tiny size does not compromise quality, recording at 640x480 @ 30 FPS using Frame Rate Enhancement technology. The Atom also introduces the ability to take photo snapshots @ 1280x960 and comes bundled with the 2GB micro SD card and sports mounting kit.
Features:
- The world's smallest high resolution camcorder
- Measures only 1.75 inch high x .75 inch wide x .75 inch deep
- Includes 2GB micro SD card (up to 8GB MSD compatible) to record up to 90 minutes footage
- Includes rechargeable battery for up to 45 minutes continuous operation
- Standby mode with noise activation
- Bundle sports kit
- Photo snapshot @ 1280 x 960
Includes:
1 x veho MUVI ATOM micro DV camcorder
1 x micro 2GB SD card
1 x USB Cable
1 x MUVI ATOM software
1 x MUVI ATOM spring mounting clip
1 x MUVI ATOM neck chain
1 x MUVI ATOM carrying pouch
1 x MUVI ATOM users manual
1 x mounting bracket for bike/helmet
1 x magnetic mounting bracket for wall
1 x MUVI ATOM head/helmet strap
1 x mounting bracket velcro
2 x mounting bracket screws
3 x mounting bracket straps
Perfect for extreme sports
The Muvi unique micro design enables digital video recording in situations where it may not be possible to use standard camcorders. Coupled with the extreme sports mounting kit the muvi will allow the user to capture high quality digital video and sound footage hands free. With its robust thumb sized alloy metal casing you needn't worry about your Veho Muvi. It features a 2 Megapixel lens and records in AVI format. -
It's the smallest in the world of its kind
The Veho Muvi comes with a 2GB Micro SD Card, that's enough for 2 hours footage, and with a built in rechargeable battery life of 2-3 hours, you'll never miss a thing. Easily connects to your computer via Micro USB, so you can upload your videos in seconds. It also charges through any USB giving complete portability. -
Great quality
The Veho Muvi Micro DV Camcorder is perfect for anyone who wants to capture great quality images whilst on the move. The Muvi DV Cam captures video with a 2 mega pixel image quality, which are then stored in AVI format on the Micro SD Memory card. Powered by the included internal li-ion rechargeable battery the Veho Muvi Digital Video Camera will keep going for up to 3 hours from a full charge, and can be connected to your PC via the included USB cable to both transfer videos and re-charge the battery, or for use as a webcam. -
Attaches easily
The Veho VCC-003 DV Camcorder is ideal for those out and about as the included clip allows it to be attached to various items, whilst it also features voice activated start/stop recording function so it can be used completely hands free when you need them for other things. Accessories available include an extreme sports pack for mounting the camera on items such as helmets for when your mountain biking, skateboarding, skiing etc., your then able to capture the action has it happens.
- Veho muvi micro DV - camcorder - storage: flash card
- Product Type
- Camcorder
- Media Type
- Flash card
- Memory Card Slot
- microSD card
- Sensor Resolution
- 2.0 MP
- Focus Adjustment
- Focus free
- Supported Battery
- Li-ion rechargeable battery (included)
- Black
- 2 cm x 1.9 cm x 4 cm
- Product Type
- Camcorder
- Enclosure Colour
- Black
- Camcorder Type
- Consumer
- Camcorder Sensor Resolution
- 2.0 MP
- Sensor Qty
- 1 CMOS
- Camcorder Media Type
- Flash card
- Optical Sensor Type
- CMOS
Exposure & White Balance
- Exposure Modes
- Programme, automatic
Lens System
- Focus Adjustment
- Focus free
- Max View Angle
- 80 degree(s)
Additional Features
- Additional Features
- Audio recording, auto power save, USB charging
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB
Software
- Software
- Drivers & Utilities
- Included Accessories
- Neck strap, mounting hardware, USB cable, spring clip, helmet mounting kit, magnet mount, handle bar mount
- Battery Type
- Lithium Ion - manufacturer-specific
- Details
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card
- Memory Card
- 2 GB microSD
- Image Storage
- JPEG 1280 x 960
- Video Capture
- 640 x 480 - 30 fps
- 2 cm
- 1.9 cm
- 4 cm
