The VMS-005-LCD standalone discovery microscope from Veho has been designed for both home and commercial purposes.
With up to 1200x digital magnification at home this microscope is the perfect educational companion for all the family as well as a great tool for the hobby enthusiast. As a commercial instrument the microscope has a wide range of commercial uses including inspection of electronics, print, hallmarks and of course medical conditions. The LCD screen and rechargeable battery make this the perfect microscope for activities out in the field or on the road. The on board micro SD slot means that images and video can be saved internally on the microscope and downloaded to a PC, Mac or iPad at a later date. Alternatively connect the microscope to a PC or Mac and used the supplied software to calibrate and measure objects.
The timelapse functionality allows timed photographs magnified at up to 1200x to enable timelapse movies such as growing mold or decaying food.
- Veho VMS-005-LCD - microscope
- Microscope
- 11.2 cm x 15.5 cm x 23 cm
- 780 g
- Connectivity Technology
- Wired
- Camera
- Optical Zoom
- 300 x
- Frame Rate (max)
- 30 frames per second
- Optical Sensor Type
- 5 MP
- Focus Adjustment
- (min distance 1 cm)
- USB 2.0, composite video
- Cables Included
- 1 - USB cable - external , 1 - video cable - external
- Built-in LED illuminator, 3.5" LCD screen
- Microscope
- Wired
- 11.2 cm
- 15.5 cm
- 23 cm
- 780 g
- Localisation
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Camera
- Digital Video Format
- AVI
- Digital Zoom
- 1200
- Frame Rate (max)
Image Sensor
- 5 MP
Lens Construction
- Optical Zoom
- 300 x
- Min Focus Distance
- 1 cm
- Video
- Composite video
- Computer Interface
- USB 2.0
- Ports
- USB 2.0 , Composite video - RCA
- Supported Memory Cards
- microSD Card, microSDHC Card
- Included Accessories
- Cleaning cloth, 4 GB microSD card, calibration target
- Cables Included
- 1 x USB cable - external , 1 x video cable - external
- Battery
- Lithium Ion 1050 mAh (up to 2 hours)
- OS Required
- Microsoft Windows XP SP2, Apple MacOS X 10.6 - 10.8, Microsoft Windows Vista / 7 / 8
- System Requirements Details
- Pentium II RAM 256 MB
