Pebble Smartstick emergency portable battery pack charger for all mobile devices
Pebble SmartStick emergency portable battery pack charger for all mobile devices. 2200mah - Special Edition 'Pink' Breast Cancer Campaign. Veho UK Ltd will donate £1 (or equivalent currency) from the sale of this product.
Charge your portable device on the move without the need for mains power. Small and light enough to carry around in your bag, the Pebble SmartStick portable emergency charger will provide your mobile device with up to one additional charge, charging most popular devices including iPhone, iPod, Blackberry, Sony Ericsson and devices that use mini or micro USB.
Key features:
- Rechargeable 2200 mAh battery, up to one full charge on your Smartphone
- Small and lightweight
- Includes 5 adaptors for use with most popular mobile devices
What's included:
- 1 x Pebble SmartStick
- 1 x USB charging cable
- 1 x Device charging cable
- 5 x device charging tips (iPhone/iPod, Sony Ericsson, Nokia pin tip, mini USB and micro USB)
- 1 x Carry pouch
- 1 x User manual
Please note the iPhone connector is compatible with the 4/4s only. It does not contain a connector for iphone 5/5s 6/6s
The Veho Pebble SmartStick portable phone charger packs 2200mah which is enough power to give most mobile devices a full charge when you leave the home or office without remembering to top up your mobile power from the mains. As well as helping you out of a powerless corner the Pebble SmartStick has a stylish micro sized design perfect for your handbag or pocket and comes with a stylish carry sock and 4 connectors for iPhone/iPod, Blackberry, HTC, Samsung, Mini USB, Micro USB, Nokia, 2 charging cables which will enable you to charge all the most popular smartphones.
- Veho Pebble Smartstick external battery pack
- Product Type
- External battery pack
- 8.6 cm
- Diameter
- 2.2 cm
- 70 g
- Pink
- Battery
- 2200 mAh
- Cables
- USB charge cable
- Compatible Mobile Devices
- Apple iPhone
- Product Type
- 8.6 cm
- Diameter
- 2.2 cm
- 70 g
- Enclosure Colour
- Pink
- Voltage Provided
- 3.7 V
- Capacity
- 2200 mAh
- Included Accessories
- Carrying pouch, 5 connector tips
- Cables Included
- USB charge cable
