Veho Pebble P1 10400mAh Portable Battery Pack Charger
Quicklinx: D379WS00 Mfr#: VPP-007-P1
The Pebble P-1 from Veho has a large 10,400mAh capacity with dual USB ports designed to enable charging of 2 devices simultaneously.
The fast 2.1A charging output has been designed to charge tablets, smartphones, Sat Nav’s, GPS’s trackers and other portable USB devices fast and efficiently.
The Pebble P-1 allows you to use your own charging cable to charge up your devices’ and is capable of charging the popular smartphones such as the iPhone 7 up to 5 times and the Samsung Galaxy S8 up to 3 times.
With a USB-C input charging port, the Pebble P-1 is compatible and future proof for new USB-C devices and cables, so you won’t have to update your power bank when you update your smartphone, tablet or portable device.
The Pebble P-1 incorporates Pebble stylish ergonomic design, which has been popular with power bank users. The power bank features a smooth matte black, Tacton rubber touch finish and a digital LED display indicator giving the exact percentage available.
Designed in the UK, the Pebble P-1 is packed with superior quality lithium-ion battery cells, ensuring that you get the true mAh rating and conform to all safety marks and regulations such as CE, RoHS and EMC.
The Pebble P-1 comes with micro-USB to USB-A charging cable, a protective carry pouch and multi-lingual user manual.
Key Features
  • Large 10,400mAh portable power bank with dual USB outputs to charge 2 devices simultaneously.
  • Fast 2.1A charging designed to charge tablets, smartphones, portable USB devices fast and efficiently
  • Fast and futureproof charging with USB-C compatible input for new USB-C devices and cables
  • Ergonomic design with digital LED indicator giving the exact percentage available
  • Superior quality lithium-ion battery that conforms to all safety marks such as CE, RoHS, and EMC.
Box Contents
  • Veho P-1 Power Bank
  • Micro USB to USB-A Charging Cable
  • Protective Neoprene Pouch
  • Multi Lingual User Manual (English, French, Spanish, German, Italian, Portuguese, Russian, Chinese & Japanese)
Veho Pebble P-1 power bank - USB
Power bank
11.5 cm x 7.8 cm x 2.55 cm
260 g
Output Connector Type
USB
5 V
Voltage Provided
5 V
Max Electric Current
2.1 A
10400 mAh
Cables
Micro-USB to USB cable
Power bank
Tablet, mobile phone
11.5 cm
7.8 cm
2.55 cm
260 g
5 V
Input Connectors
5 pin Micro-USB Type B, 24 pin USB-C
Voltage Provided
5 V
Output connectors
4 pin USB Type A
2.1 A
LED indicator
10400 mAh
On/off button
Carrying pouch
EMC, RoHS
