Powerhouse
Superior quality lithium-ion cells, 10,400 mAh capacity with dual USB outputs to charge 2 devices simultaneously. -
Surge protection
Auto shut-off mode to protect against short circuit, over-current, over-charging and over-discharging. -
Power indicator
LED power indicator means you can keep a close eye on the exact capacity when charging your devices.
- Veho Pebble P1 Pro power bank - USB
- Product Type
- Power bank
- 7.8 cm x 2.55 cm x 11.5 cm
- 260 g
- Output Connector Type
- Total 2: USB - on cable: Micro-USB, Lightning
- Voltage Required
- 5 V
- Voltage Provided
- 5 V
- Max Electric Current
- 2.1 A
- Battery
- 10400 mAh
- Cables
- Micro-USB to USB cable , Lightning to USB cable
- Product Type
- Power bank
- 7.8 cm
- 2.55 cm
- 11.5 cm
- 260 g
- Voltage Required
- 5 V
- Input Connectors
- 5 pin Micro-USB Type B, 24 pin USB-C
- Voltage Provided
- 5 V
- Output connectors
- Total 2: 4 pin USB Type A
- Detachable Cable Connector Type
- Micro-USB Type B, Lightning
- 2.1 A
- Capacity
- 10400 mAh
- LED power meter, short circuit protection, auto shut-off
- Included Accessories
- Carrying pouch
- Cables Included
