Veho Pebble Ministick Portable Rechargeable Power Bank 2200 mAh
Quicklinx: F5YCWS00 Mfr#: VPP-102-BL-2200
Top-up your essential devices on the move without the inconvenience of finding a power outlet, thanks to the improved emergency rechargeable Pebble Ministick from Veho. With a soft-touch finish, the Veho Pebble Ministick also has a handy loop, ideal for either putting on a set of keys.
Veho Pebble Ministick power bank - Li-Ion - USB
Power bank
10.25 cm x 2.28 cm
62 g
Output Connector Type
USB - on cable: Micro-USB
5 V
Voltage Provided
5 V
Max Electric Current
1 A
Lithium Ion - 2200 mAh
Cables
Micro-USB to USB cable
Power bank
10.25 cm
2.28 cm
62 g
Enclosure Colour
5 V
Input Connectors
5 pin Micro-USB Type B
Voltage Provided
5 V
Output connectors
4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
1 A
Lithium Ion
2200 mAh
LED power meter, built-in key ring, Tacton rubber finish
USB charging cable
EMC, RoHS
