The PEBBLE Explorer has a large 8400 mAh capacity and dual USB port designed to enable charging of 2 devices at any one time. With a 2.1 A output the PEBBLE Explorer is designed to charge tablets in the most efficient way. This means that your tablet power is replaced as quickly as possibly when you're low on charge and away from a mains source. Don't worry if your smartphone is also low on charge because the Explorer's dual port design means it's capable of charging 2 devices at the same time. The powerful 8400 mAh battery can give most tablets a complete full charge and most smartphones up to 5 charges.
The stylish blue LED power indicator means you can keep a close eye on the Explorer's exact capacity when charging your devices and also when you are recharging your Explorer. An long hour mains charge to the Explorer will give your portable devices hours of additional usage while you are away from the mains which makes it the perfect companion for camping, trekking, festivals as well as business users who easily drain their portable devices during a long busy day.
- Veho Pebble Explorer - external battery pack
- Product Type
- External battery pack
- 7.5 cm x 9.2 cm x 2.3 cm
- 192 g
- Voltage Required
- 5 V
- Voltage Provided
- 5 V
- Battery
- 8400 mAh
- Product Type
- 7.5 cm
- 9.2 cm
- 2.3 cm
- 192 g
- Voltage Required
- 5 V
- Input Connector(s)
- 1 x 5 pin Micro-USB Type B (power only)
- Voltage Provided
- 5 V
- Output Connector(s)
- Total 2 : 4 pin USB Type A (power only)
- Max Electric Current
- 2.1 A
- Short circuit protection, overcharging protection, over-current protection, overdischarging protection, shuts off automatically
- Voltage Provided
- 3.7 V
- Capacity
- 8400 mAh
- Recharge Time
- 8 hour(s)
- LED power meter, on/off button
- Included Accessories
- Carrying pouch, 3 connector tips (DUAL Samsung / Apple 30 Pin Tip)
- Cables Included
- USB charge cable - external
