Veho Muvi X-Drone VXD-A003-SB Spare battery 5300mah battery
Quicklinx: BNJXWS00 Mfr#: VXD-A003-SB
This spare battery allows you to add more flight time by instantly changing the drone's replaceable battery. The battery is extremely large and provides your drone an additional flight time. The battery also has a built-in, one touch status indicator on the face of the battery, so you can ensure that it's fully charged before you take flight. Carry a spare battery with you and you can be sure you'll never miss that amazing shot.
Veho battery - Li-pol
Drone
Lithium polymer - 5300 mAh
Muvi X-Drone
Drone
Lithium polymer
Voltage Provided
11.1 V
5300 mAh
Run Time (Up To)
20 min
Veho Muvi X-Drone
