Veho Muvi X-Drone VXD-001-B quadcopter with built-in 1080p Camera
Quicklinx: BNJTWS00 Mfr#: VXD-001-B
"The Muvi X-Drone is incredibly easy to fly, and comes with everything you need to get started. So whether you’re a first time flyer or a professional, the X-Drone is the perfect aerial camera system for any camera enthusiast with little or no prior experience. The X-Drone has auto locking motors to secure the propellers and also comes with propeller guards. If you’re a first time flyer, or a professional flying in confined spaces, the prop guards will protect arrange damage or injury.
The X-Drone has a built-in Muvi camera that produces high quality HD 1080p videos at 30fps or 720p at 60fps. The Muvi camera on the X-Drone can also take stunning 16 mega pixel still images. The camera has image and video stabilization, which will allow you shoot smooth high quality videos, from an aerial point of view. The X-Drone has a built-in microSD slot which can take up to 64GB memory card, allowing you to capture up to 260 minutes video or over 11,000 images.
Fly up to 20 minutes, thanks to the X-Drone’s powerful rechargeable and removable 5,300mAh Li-Po battery, the largest on the market. The battery also has built in status indicator on the face of the battery, so you can ensure that it’s fully charged before you take flight.
The advanced GPS system now makes it even easier to fly your X-Drone, the GPS allows you to maintain altitude and orientation to allow you to focus on filming, and the automatic flight control system, means that if you lose control or satellite signal, the X-Drone will return itself to its launch point and then land itself safely.
The easy to use X-drone remote control makes it simple enough for first time or professional users to use immediately after configuration. The easy to navigate remote control allows for flight and camera giro control from up to five hundred meters. Using the smartphone cradle, you can live view from the X-Drone directly to your smartphone screen.
Record videos or capture photo’s directly from X-Drone thanks to the free APP that’s available on iOS or Android. The APP can also be used for live streaming, so you can see what the Muvi camera on-board the X-Drone sees. The APP will also allow you to check the status of the Wi-Fi, battery and also make changes to the settings of your X-Drone.
The X-Drone also comes with a pre-paired, USB rechargeable smartphone range extender, which increases the connectivity between the X-Drone and the smartphone up to 300 metres; you can make sure that you are always in range when connected to the live view screen on your smartphone APP.
The bright LED’s underneath the X-Drone, make sure you are able to judge the correct orientation of X-Drone. These indicators also give you use notifications during flight such as battery strength and GPS connectivity. "
Veho - Muvi X-Drone
