Veho Muvi Pro Micro DV 4Gb Camcorder
Quicklinx: 6KZNWS00 Mfr#: VCC-003-MUVI-PRO
Muvi Pro Micro DV Camcorder with 4GB Micro SD Card Included. The Smallest DV Camcorder in the world!
Muvi Pro's Multiple Uses
The Muvi Pro picks up from the original Muvi only this time with an enhanced frame rate of 30fps, a 4GB Micro SD card and time/date stamp allowing the user to document their footage. The Muvi Pro is therefore especially useful for security purposes allowing users to record all footage with a time/date displayed at all times.
The micro design enables digital video recording in situations where it may not be possible to use standard camcorders. Coupled with the extreme sports mounting kit the muvi will allow the user to capture high quality digital video and sound footage hands free. With its robust thumb sized alloy metal casing you needn't worry about your Veho Muvi Pro. It features a 2 Megapixel lens and records in AVI format.
It's the smallest in the world of its kind
The Veho Muvi Pro comes with a 4GB Micro SD Card, that's enough for 4 hours footage, and with a built in rechargeable battery life of 2-3 hours, you'll never miss a thing. Easily connects to your computer via Micro USB, so you can upload your videos in seconds. It also charges through any USB giving complete portability.
Great quality
The Veho Muvi Pro Micro DV Camcorder is perfect for anyone who wants to capture great quality images whilst on the move. The Muvi Pro DV Cam captures video at 30 frames per second with 2 mega pixel image quality, these are then stored in AVI format on the Micro SD Memory card. Powered by the included internal li-ion rechargeable battery the Veho Muvi Pro Digital Video Camera will keep going for up to 3 hours from a full charge, and can be connected to your PC via the included USB cable to both transfer videos and re-charge the battery, or for use as a webcam.
Attaches easily
The Veho VCC-003-Pro DV Camcorder is ideal for those out and about as the included clip allows it to be attached to various items, whilst it also features voice activated start/stop recording function so it can be used completely hands free when you need them for other things. Accessories available include an extreme sports pack for mounting the camera on items such as helmets for when your mountain biking, skateboarding, skiing etc., your then able to capture the action has it happens.
Optional Extreme Sports Kit for Muvi Camcorder- Quicklinx - 69LZ
Optional Waterproof case for Muvi - Quicklinx - 6KX8
Optional Pro handlebar mount for Muvi - Quicklinx - 6KX9
