The Muvi KX-2 Pro is our most advanced action camera to date. The tiny but powerful camera captures stunning UHD 4K@30fps / 1080p@100fps video and spectacular 12MP photos that can be streamed or shared over Wi-Fi directly to your smartphone thanks to the free, easy to use app. The Muvi KX-2 Pro comes with a 40m waterproof housing, a quick release frame, 16GB microSD card and ships in this protective rugged carry pouch.
CAPTURE IN 4K
Ultra high-resolution video capture 4k@30fps and high definition 1080p@100fps
12MP STILL PHOTOS
Shoot 12MP single photos with a selection of photo modes including time lapse, high speed photo burst and 180° rollover mode.
WATERPROOF CASE
Includes waterproof case capable of depths up to 40m, perfect for watersports and diving.
TOUCHSCREEN
1.8" Smart LCD touch screen to preview videos and photos and to easily navigate the menu to change settings and preferences.
MEMORY INCLUDED
Ships with 16GB microSD card
STREAM VIA APP
The Muvi app allows you to live view, record and even share your content straight onto social media (iOS & Android).
Capture in 4K
Ultra high-resolution video capture 4k@30 fps and high definition 1080p@100 fps. -
12MP still photos
Shoot 12MP single photos with a selection of photo modes including time lapse, high speed photo burst and 180° rollover mode. -
Touchscreen
- Veho muvi KX-2 Pro - action camera
- Product Type
- Action camera - 4K
- Action Camera Type
- Mountable
- Memory Card Slot
- microSD card
- Wireless Interface
- Wireless LAN
- Sensor Resolution
- 12.0 MP
- Max Video Resolution
- 3840 x 2160
- Lens System
- Wide-angle lens f/2.7
- Focus Adjustment
- Focus free
- Display
- LCD display - 1.8"
- Supported Battery
- Li-ion rechargeable battery - 1050 mAh (included)
- 5.2 cm x 2.6 cm x 4 cm
- 67 g
- Product Type
- Camcorder Sensor Resolution
- 12.0 MP
- Widescreen Video Capture
- Frame Rate (Max Resolution)
- 30 fps
- 3840 x 2160
- Interface
- Wireless LAN
- Connectivity Features
- Remote live view, Wireless Image Transfer
Lens System
- Focus Adjustment
- Focus free
- Max View Angle
- 140 degree(s)
Action Camera Features
- Camera Type
- Mountable
- Time-Lapse recording
Display
- 1.8" LCD display
- Display Form Factor
- Built-in
- Touch Screen
- Included Accessories
- Cleaning cloth, USB cable, underwater housing, protective pouch, curved adhesive mount, stickers, flat adhesive mount, anti-fog inserts, mounting frame
- Underwater Use
- Underwater Depth
- Up to 40 m
- Battery Type
- Lithium Ion - manufacturer-specific
- Details
- Battery Life Details
- Video recording - 2 hours
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card
- Memory Card
- 16 GB microSDHC
- Memory Card Included
- Video Capture
- 3840 x 2160 p - 30 fps , 1920 x 1080 p - 100 fps
- 5.2 cm
- 2.6 cm
- 4 cm
- 67 g
