This easy-to-use camera offers UHD recording 4K10/1080p60 video and superb 12MP photos that can be streamed or shared directly to your smartphone. The Muvi KX-1 comes with a 40m waterproof housing and a quick release frame.
- Veho muvi KX-1 - action camera
- Product Type
- Action camera - 4K
- Action Camera Type
- Mountable
- Wireless Interface
- Wireless LAN
- Effective Sensor Resolution
- Photo: 12.0 MP
- Max Video Resolution
- 3840 x 2160
- Lens System
- Wide-angle lens f/2.5
- Focus Adjustment
- Focus free
- Display
- LCD display - 1.8"
- Supported Battery
- 1050 mAh (included)
- 5.2 cm x 2.6 cm x 4 cm
- 67 g
- Product Type
- Effective Photo Resolution
- 12.0 MP
- Widescreen Video Capture
- Frame Rate (Max Resolution)
- 10 fps
- 3840 x 2160
- Interface
- Wireless LAN
- Connectivity Features
- Remote control via mobile devices, remote live view
Lens System
- Focus Adjustment
- Focus free
- Max View Angle
- 140 degree(s)
Additional Features
- Additional Features
- Interval shooting mode, slow motion recording
Action Camera Features
- Camera Type
- Mountable
Display
- 1.8" LCD display
- Display Form Factor
- Built-in
- Touch Screen
- Included Accessories
- Cleaning cloth, USB cable, quick release adapter, underwater housing, curved adhesive mount, stickers, flat adhesive mount, anti-fog inserts
- Underwater Use
- Underwater Depth
- Up to 40 m
- Battery Type
- Manufacturer-specific
- Details
Memory / Storage
- Video Capture
- 3840 x 2160 - 10 fps , 1920 x 1080 - 60 fps
- 5.2 cm
- 2.6 cm
- 4 cm
- 67 g
