Veho Muvi HD10 Lite Micro Digital Camcorder Handsfree Action
Quicklinx: F6MDWS00 Mfr#: VCC-003-MUVI-NM
Type: Camcorder
Media Type: Flash card
Video Input: USB 2.0
26 in stock
£39.38 ex VAT
£47.25 inc VAT
Introducing our new and updated Muvi Micro HD10L Camcorder, capable of recording HD footage 1080p@30fps the HD10L captures all the action as it happens. The HD10L measures at just 55mm x 22mm x 20mm, making it one of the smallest action cameras on the market. The unique size of the HD10L allows the camera to be mounted in a variety of situations including extreme sports. Included in the box contents is a Spring Clip which allows you to attach the camera to an item of clothing and keep it in a fixed position for capturing footage handsfree.
CAPTURE IN HD
HD video capture 1080p@30fps
MICRO SIZED
Measuring only 55mm x 22mm x 20mm it's unique size allows the camera to be mounted in a variety of situations
PLUG & PLAY
The Muvi Micro connects to your computer via micro USB, so you can upload your footage and play it back without any hassle
Veho Muvi Micro HD10L - camcorder - storage: flash card
Camcorder - 1080p - widescreen
Media Type
Flash card
Memory Card Slot
microSD card
Sensor Resolution
2.0 MP
Max Video Resolution
1920 x 1080
Lens System
Wide-angle lens
Focus Adjustment
Focus free
Supported Battery
1 x 540 mAh (included)
USB 2.0
2.2 cm x 2 cm x 5 cm
50 g
Camcorder - 1080p
Camcorder Type
Mountable
Camcorder Sensor Resolution
2.0 MP
Sensor Qty
1 CMOS
Widescreen Video Capture
Camcorder Media Type
Flash card
Optical Sensor Type
CMOS
Frame Rate (Max Resolution)
30 fps
Digital Video Format
AVI
1920 x 1080
USB 2.0
Exposure & White Balance
Exposure Modes
Programme, automatic
White Balance
Automatic
Lens System
Wide-angle lens - wide angle
Focus Adjustment
Focus free
Max View Angle
74 degree(s)
Additional Features
Additional Features
USB charging, voice activated recording
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 (5 pin Micro-USB Type B)
USB cable, spring clip
Battery Type
Integrated
Run Time (Up To)
80 min
Details
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card
Memory Card Max Supported Size
32 GB
Video Capture
AVI - 1920 x 1080 p - 30 fps - 83Mbps
2.2 cm
2 cm
5 cm
50 g
-10 °C
60 °C
Type: Camcorder
Brand: Veho
Price Range Ex VAT: 0 - 50
