Veho Muvi HD Pro Bodycam
Quicklinx: HG8KWS00 Mfr#: VCC-005-HDPRO3
£244.90 ex VAT
£293.88 inc VAT
Discover the Veho muvi HD Pro 3 Titan, a camcorder designed for the modern adventurer. This wearable device doesn't just capture moments; it ensures every detail is recorded in vivid clarity, thanks to its 1080p high-definition video capability. With a wide-angle lens offering a 120-degree view, users can capture expansive scenes in stunning detail.
Durability is at the core of the HD Pro 3 Titan's design. It boasts IP67 protection, rendering it resistant to dust, water, and adverse weather conditions, making it the perfect companion for outdoor enthusiasts. Additionally, the camcorder is equipped with night vision infrared imaging, allowing for clear recording in low-light conditions, ensuring no moment is missed.
The device is built for extended use, featuring a 3600 mAh battery and 64 GB of internal storage, minimizing the need for frequent charging or data transfer. Whether you're exploring rugged terrains or capturing the night's ambiance, the Veho muvi HD Pro 3 Titan is your reliable partner in adventure.
  • Rugged design
    Built to withstand the elements, the Veho muvi HD Pro 3 Titan features IP67 protection, making it dust-resistant, water-resistant, and weather-resistant. Ideal for adventurers and outdoor enthusiasts who demand durability in their equipment.
  • Exceptional video quality
    Capture every moment in stunning detail with the HD Pro 3 Titan's ability to record in 1080p high-definition video. Supported by a CMOS optical sensor and a wide-angle lens with a 120-degree view, this camcorder ensures vivid, expansive recordings in a variety of settings.
  • Night vision capability
    Don't let low-light conditions hinder your recording. The HD Pro 3 Titan comes equipped with night vision infrared imaging, allowing for clear video capture in darker environments, ensuring no moment is missed, regardless of the time of day.
  • Extended recording time
    With a 3600 mAh battery and 64 GB of internal flash storage, the Veho muvi HD Pro 3 Titan is designed for long recording sessions, ensuring you have the power and space to capture extensive footage without constant interruptions for charging or data transfer.
Veho muvi HD Pro 3 Titan - camcorder
Camcorder - 1080p
Internal Storage
64 GB flash
Max Video Resolution
1920 x 1080
Lens System
Wide-angle lens
Focus Adjustment
Focus free
Display
LCD display - 0.9"
Supported Battery
3600 mAh (included)
6 cm x 2.8 cm x 9.1 cm
156 g
Camcorder - 1080p
Camcorder Type
Wearable
Sensor Qty
2 CMOS
Optical Sensor Type
CMOS
Frame Rate (Max Resolution)
30 fps
Digital Video Format
MP4, H.264
1920 x 1080
Lens System
Wide-angle lens - wide angle
Focus Adjustment
Focus free
Max View Angle
120 degree(s)
Additional Features
Low Lux / Night Mode
Additional Features
Date/time stamp, night vision infrared imaging, USB charging, ruggedised
Display
0.9" LCD display
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Clip mount, USB charging cable
Protection
IP67, weather-resistant, water-resistant, dust-resistant
Battery Type
Manufacturer-specific
Run Time (Up To)
15 hour(s)
Details
3600 mAh (included)
Battery Life Details
Video recording - 15 hours , Standby mode - 300 hours
Memory / Storage
Internal Storage
64 GB flash
Video Capture
MPEG-4 - 1920 x 1080 p - 30 fps , MPEG-4 - 1280 x 720 p - 30 fps , MPEG-4 - 640 x 480 p - 30 fps
6 cm
2.8 cm
9.1 cm
156 g
Brand: Veho
