The latest addition to the popular MUVI micro camcorder range introduces the MUVI HD10 mini handsfree camcorder. The HD 10 captures handsfree high definition footage and snapshot using the 160 degree super wide angle lens and the sensa wireless remote control. The HD10 also includes a self timer, noise activation, touch panel, digital zoom and ships with a 4GB Micro SD card (upgradable to 32GB) and a 1400mah internal battery that will give 4hrs record time . As well as the rich technical specifications the MUVI also comes with a range of sports mounting clips and accessories that enables you to record in almost any situation.
- Veho muvi HD10 - action camera
- Product Type
- Action camera - 1080p
- Action Camera Type
- Mountable
- Memory Card Slot
- microSD card
- Sensor Resolution
- 5.0 MP
- Lens System
- F/2.5
- Focus Adjustment
- Automatic
- Min Focus Distance
- 2.5 cm
- Digital Zoom
- 3x
- Display
- LCD display - 1.5"
- Supported Battery
- Li-ion rechargeable battery - 1400 mAh (included)
- 4.7 cm x 1.9 cm x 8 cm
- 81 g
- Product Type
- Camcorder Type
- Wearable
- Camcorder Sensor Resolution
- 5.0 MP
- Sensor Qty
- 1 CMOS
- Widescreen Video Capture
- Optical Sensor Type
- CMOS
- ISO (Max)
- 200
- Digital Zoom
- 3x
Exposure & White Balance
- Light Sensitivity
- ISO 100, ISO 200
Lens System
- F/2.5
- Focus Adjustment
- Automatic
- 2.5 cm
- Max View Angle
- 160 degree(s)
Additional Features
- Additional Features
- Audio recording, auto power save, USB charging, sound activated recording, touch panel control
Action Camera Features
- Camera Type
- Mountable
Display
- 1.5" LCD display
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB
- Included Accessories
- Spring clip, helmet mounting kit, radio remote control
- Battery Type
- Lithium Ion - manufacturer-specific
- Run Time (Up To)
- 4 hour(s)
- Details
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card
- Memory Card
- 4 GB microSDHC
- Video Capture
- 1920 x 1080 - 30 fps , 1280 x 720 - 30 fps
- 4.7 cm
- 1.9 cm
- 8 cm
- 81 g
