The MUVI extra-long extendable monopod from Veho is the perfect monopod for action sports enthusiasts and prosumer filmers. With a super soft rubberized ergonomic grip and adjustable wrist leash it fits perfectly in the hand and will ensure that even if you wipe out you won't lose your camera.
Un-extended the MUVI monopod is 62 cm (24 inches) and using the 2 telescopic extenders with locking joints reaches to a huge 145 cm (57 inches). The MUVI monopod is fitted with a multi directional swivel and locking head and tripod mount which all amounts to self-filming and angles that other smaller monopods are just not capable of.
- Veho MUVI Extra-Long Extendable monopod
- Product Type
- Monopod
- Tripod Operating Height
- 62 cm - 145 cm
- Designed For
- Muvi Atom, HD, HD10
- Product Type
- Monopod
- Folded Length
- 62 cm
Tripod
- Tripod Legs Sections Qty
- 3
- Tripod Legs Lock Type
- Flip lock lever
- Max Operating Height
- 145 cm
- Min Operating Height
- 62 cm
- Supported Devices
- Camcorder, camera
- Included Accessories
- Strap, mounting adapter
- Designed For
- Veho muvi Atom, HD, HD10
