Pack of 3 x MUVI 3M Flat Adhesive Mounts for use with your MUVI or MUVI HD camcorder. These mounts allow you to mount your MUVI camcorder securely to any flat surface. They will hold your camcorder securely in place but can easily be removed by applying heat, such as using a hair dryer.
- Veho MUVI 3M Flat Adhesive Mounts support system - adhesive mount
- Product Type
- Support system - adhesive mount
- Designed For
- Muvi Atom, HD, HD10, Pro DV
- Product Type
- Support system
Tripod
- Supported Devices
- Action camera
- Support Type
- Adhesive mount
Kit Content
- Kit Content
- (3) x adhesive mounting base
- Designed For
- Veho muvi Atom, HD, HD10, Pro DV
