The MUVI universal triple cup suction mount is designed for professional and prosumer use on all flat surfaces that might be moving at high speeds such as vehicles, boats or aircraft. Each suction cup is fitted with its own suction lock and quick release mechanism and has an adjustable design so it can be mounted at different angles to fit many different scenarios or mounting options.
This mount ships with 2 sized adjustable arms for mounting your MUVI, action cam or camera. The small arm measures 9 cm (3 inches) and the larger arm 12 cm (5 inches) and both allow swivel head connection to the MUVI cradle or a universal tripod mount.
- Veho MUVI 3 Cup Pro Suction Mount support system - suction mount
- Product Type
- Support system - suction mount
- Designed For
- Muvi Atom, HD, HD10
- Product Type
- Support system
Tripod
- Supported Devices
- Action camera
- Support Type
- Suction mount
Kit Content
- Kit Content
- (1) x suction cup mount , (1) x mounting arm - 9 cm , (1) x mounting arm - 12 cm , (1) x tripod adapter
- Designed For
- Veho muvi Atom, HD, HD10
