- Veho M-8 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Speaker Type
- Active
- Continuous Power
- 20 Watt
- Frequency Response
- 60 - 18000 Hz
- Amplifier
- Integrated
- Bluetooth
- Speaker Details
- Speaker 2 - 10 Watt - 60 - 18000 Hz - <2% THD - 4 Ohm - active
- Battery
- Speaker battery rechargeable
- 9.3 cm
- Dimensions - Diameter
- 17 cm
- 550 g
- Product Type
- Enclosure Material
- Aluminium
Speaker System
- Speaker Type
- Active
- Continuous Power
- 20 Watt
- 60 - 18000 Hz
- Signal-To-Noise Ratio
- 85 dB
- Amplifier
- Integrated
- Bluetooth 4.0
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Speaker System Details
- Speaker Details
- Speaker 2 - 10 Watt - 60 - 18000 Hz CFR - <2% THD - 4 Ohm - active
- Driver Details
- Speaker: 2 x full-range driver , Speaker: 2 x Passive Radiator
- Connector Type
- Audio line-in (mini-phone 3.5mm)
- Included Accessories
- Audio cable, micro-USB charging cable
- Rechargeable
- Capacity (Ah)
- 2200 mAh
- Run Time (Up To)
- 15 hours
- Recharge Time
- 4 hours
- Diameter
- 17 cm
- 9.3 cm
- 550 g
