Veho M-Series MZ-S Wireless Speaker – Black
Quicklinx: HPRSWS00 Mfr#: VSS-701-MZS-B
£16.54 ex VAT
£19.84 inc VAT
The Veho MZ-S speaker is designed for those who seek quality and convenience in their audio experience. This portable speaker is not just a device but a gateway to enjoying your favorite music wherever you go. With its Bluetooth 5.0 connectivity, it offers seamless wireless audio up to 10 m away, freeing you from the constraints of cables. The 1200 mAh rechargeable battery ensures that your music keeps playing for hours, with a quick recharge time of only 4.5 hours.
The Veho MZ-S doesn't just play music; it immerses you in it. Thanks to its integrated amplifier and a continuous power output of 5 W, every note comes through clear and strong. The True Wireless Stereo (TWS) system allows for a multiroom setup, enveloping you in rich, high-quality sound. Additionally, the speaker is equipped with intuitive controls for play/pause, power, and volume, along with a hands-free function, making it as user-friendly as it is powerful. Whether at home or on-the-move, the Veho MZ-S speaker is your companion for a superior audio experience.
  • Wireless freedom
    Experience wireless audio with the Veho MZ-S speaker. Equipped with Bluetooth 5.0, it offers a stable connection up to 10 m away, allowing you to enjoy your music without being tethered to your device.
  • All-day listening
    With a 1200 mAh rechargeable battery, this speaker provides hours of uninterrupted audio playback. The battery recharges in just 4.5 hours, ensuring your music is ready to go when you are.
  • Enhanced audio experience
    The Veho MZ-S features an integrated amplifier and a continuous power output of 5 W, delivering clear, powerful sound. The True Wireless Stereo (TWS) system allows for multiroom audio, filling your space with immersive sound.
  • Convenient controls
    Designed for ease of use, the speaker comes with intuitive controls for play/pause, power on/off, and volume adjustments. The hands-free function enhances usability, making it perfect for both music and calls.
Veho MZ-S - speaker - for portable use - wireless
Speaker - for portable use
Media Content Source
Flash memory card
Speaker Type
Active
Continuous Power
5 Watt
Amplifier
Integrated
Supported Memory Cards
microSD
Bluetooth
Speaker battery rechargeable
10.5 cm
Dimensions - Diameter
7.5 cm
258 g
1-year warranty
Flash memory card
Hands-Free Function
Microphone
Enclosure Colour
Speaker System
Speaker Type
Active
Continuous Power
5 Watt
Multiroom
Multiroom Technology
True Wireless
Amplifier
Integrated
Bluetooth 5.0
Transmission Range
10 m
Controls
Power on/off, volume, play/pause
Additional Features
Memory Card
microSD
Max Supported Size
32 GB
Connector Type
USB (power only) (5 pin Micro-USB Type B)
Micro-USB charging cable
Power Source
Rechargeable
Capacity (Ah)
1200 mAh
Run Time (Up To)
12 hours
Recharge Time
4.5 hour(s)
Diameter
7.5 cm
10.5 cm
258 g
Limited warranty - 1 year
Brand: Veho
