The Veho MZ-S speaker is designed for those who seek quality and convenience in their audio experience. This portable speaker is not just a device but a gateway to enjoying your favorite music wherever you go. With its Bluetooth 5.0 connectivity, it offers seamless wireless audio up to 10 m away, freeing you from the constraints of cables. The 1200 mAh rechargeable battery ensures that your music keeps playing for hours, with a quick recharge time of only 4.5 hours.
The Veho MZ-S doesn't just play music; it immerses you in it. Thanks to its integrated amplifier and a continuous power output of 5 W, every note comes through clear and strong. The True Wireless Stereo (TWS) system allows for a multiroom setup, enveloping you in rich, high-quality sound. Additionally, the speaker is equipped with intuitive controls for play/pause, power, and volume, along with a hands-free function, making it as user-friendly as it is powerful. Whether at home or on-the-move, the Veho MZ-S speaker is your companion for a superior audio experience.
Wireless freedom
Experience wireless audio with the Veho MZ-S speaker. Equipped with Bluetooth 5.0, it offers a stable connection up to 10 m away, allowing you to enjoy your music without being tethered to your device. -
All-day listening
With a 1200 mAh rechargeable battery, this speaker provides hours of uninterrupted audio playback. The battery recharges in just 4.5 hours, ensuring your music is ready to go when you are. -
Enhanced audio experience
The Veho MZ-S features an integrated amplifier and a continuous power output of 5 W, delivering clear, powerful sound. The True Wireless Stereo (TWS) system allows for multiroom audio, filling your space with immersive sound. -
Convenient controls
Designed for ease of use, the speaker comes with intuitive controls for play/pause, power on/off, and volume adjustments. The hands-free function enhances usability, making it perfect for both music and calls.
- Veho MZ-S - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Media Content Source
- Flash memory card
- Speaker Type
- Active
- Continuous Power
- 5 Watt
- Amplifier
- Integrated
- Supported Memory Cards
- microSD
- Bluetooth
- Black
- Battery
- Speaker battery rechargeable
- 10.5 cm
- Dimensions - Diameter
- 7.5 cm
- 258 g
- 1-year warranty
- Product Type
- Flash memory card
- Hands-Free Function
- Microphone
- Enclosure Colour
- Black
Speaker System
- Speaker Type
- Active
- Continuous Power
- 5 Watt
- Multiroom
- Multiroom Technology
- True Wireless
- Amplifier
- Integrated
- Bluetooth 5.0
- Transmission Range
- 10 m
- Controls
- Power on/off, volume, play/pause
- Additional Features
- True Wireless Stereo (TWS) system
Memory Card
- microSD
- Max Supported Size
- 32 GB
- Connector Type
- USB (power only) (5 pin Micro-USB Type B)
- Included Accessories
- Micro-USB charging cable
- Power Source
- Battery
- Rechargeable
- Capacity (Ah)
- 1200 mAh
- Run Time (Up To)
- 12 hours
- Recharge Time
- 4.5 hour(s)
- Diameter
- 7.5 cm
- 10.5 cm
- 258 g
- Limited warranty - 1 year
