The Veho M2 is an ultra-compact, portable Bluetooth wireless speaker from the M-Series range. The M2 features a powerful rechargeable battery that delivers up to 10 hours of music playback. Additional the M2 speaker can be paired with another M2 speaker for an even bigger sound.
Portable
Ultra-compact sized wireless speaker, that still packs a punch. -
No wires
Easy to pair speaker connects with smartphones, tablets, MP3 players or any other Bluetooth device. -
Long playback time
Up to 10 hours of music playback from one charge. -
Pair with another M2
Pair with another M2 speaker and play simultaneously.
- Veho M-Series M2 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Speaker Type
- Active
- Nominal Output Power
- 3 Watt
- Frequency Response
- 100 - 16000 Hz
- Amplifier
- Integrated
- Bluetooth
- Speaker Details
- Speaker - mono - 3 Watt - 100 - 16000 Hz - active
- Power Options
- USB powered
- Battery
- Speaker battery rechargeable
- 7.8 cm x 7.8 cm x 5 cm
- 149 g
- Product Type
Speaker System
- Speaker Type
- Active
- 3 Watt
- 100 - 16000 Hz
- Amplifier
- Integrated
- Bluetooth 4.2
- Transmission Range
- 10 m
- Additional Features
- Stereo Wireless Link
Speaker System Details
- Speaker Details
- Speaker - mono - 3 Watt - 100 - 16000 Hz CFR - active
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- USB charging cable
- Power Source
- Battery
- Options
- USB powered
- Rechargeable
- Capacity (Ah)
- 300 mAh
- Run Time (Up To)
- 10 hour(s)
- Recharge Time
- 2 hour(s)
- 7.8 cm
- 7.8 cm
- 5 cm
- 149 g
