Enjoy low energy adaptive lighting with the Kasa smart lighting Bluetooth wireless LED spotlight bulbs. Automate your home lighting wirelessly through the Kasa app for iOS and Android.
The Kasa smart lighting GU10 Bluetooth 5 watts (40 watts converted) LED spotlight bulb will give you long hours of adaptive low energy lighting. In conjunction with the Kasa smart lighting app for iOS and Android you can enable a world of adaptive and creative lighting while automating you home lighting through the power of your smartphone or tablet.
With white or yellow light hue and 16 million dimmable colors available, you can preset groups of rooms or moods so that you can control and adapt the lighting of your home environment at the touch of your smartphone or tablet.
- Veho Kasa - LED light bulb
- Light Bulb Type
- LED light bulb
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Socket Type
- GU10
- Wattage
- 5 W
- Wattage Equivalent
- 40 W
- Light Bulb Energy Efficiency Class
- A+
- Colour of Illumination
- 16 million colours
- Dimmable
- Remote controlled, power off timer
Light Bulb
- LED light bulb
- Socket Type
- GU10
- Wattage
- 5 W
- 40 W
- A+
- Energy Consumption per 1000h
- 5 kWh
- Dimmable
- Lifetime
- 15000 hours
- Android compatible, iOS compatible, controlled via Bluetooth 4.0 Low Energy
- Package
- Box
- Diameter
- 50 mm
- Length
- 56 mm
