- Veho Kasa - LED light bulb - E14 - 5 W - 16 million colours
- Light Source Type
- LED light bulb
- Socket Type
- E14
- Wattage
- 5 W
- Wattage Equivalent
- 7.5 W
- Energy Efficiency Class
- A+
- Colour of Illumination
- Luminous Power
- 300 lumens
- Dimmable
- Communications Technology
- Bluetooth Low Energy (LE)
- Voltage Required
- AC 85 - 245 V
- Frequency Required
- 50/60 Hz
Light Source
- LED light bulb
- Socket Type
- E14
- Wattage
- 5 W
- 7.5 W
- A+
- Luminous Power
- 300 lumens
- Dimmable
- Lifetime
- 15000 hours
- Android compatible, iOS compatible, controlled via Bluetooth 4.0 Low Energy, remote controlled
Power Requirements
- Voltage Required
- AC 85 - 245 V
- 50/60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Diameter
- 50 mm
- Length
- 101 mm
