Control your next presentation with the V7 professional wireless presenter. Its ergonomic design with soft-touch finish fits comfortably in the palm of your hand and provides 5 control buttons to effortlessly navigate through your presentation. The high performance red laser pointer lets you emphasize key points to your audience.
- V7 Professional Wireless Presenter presentation remote control
- Presentation remote control
- 3.2 cm x 13.3 cm x 2.8 cm
- 37.6 g
- Connectivity Technology
- Radio
- Buttons Qty
- 5 buttons
- Max Operating Distance
- 11 m
- Battery
- 2 AAA type
- 2-year warranty
- 3.2 cm
- 13.3 cm
- 2.8 cm
- 37.6 g
- Radio
- Buttons Qty
- 5 buttons
- 11 m
- Built-in laser pointer
- Connector Type
- 1 x USB (4 PIN USB Type A)
- Included Accessories
- Carrying case, USB receiver with microSD card reader
- FCC, RoHS, WEEE
- Battery
- 2 AAA type
- Limited warranty - 2 years
