The ambidextrous compact wireless 2.4 GHz Plug and Play optical LED mouse has a premium finish for comfortable use. This high quality, space saving, 3 button mouse includes a built-in scroll wheel for quick navigation. The 1600 dpi high performance optical sensor provides smooth and precise cursor control on large high resolution displays. The smart power management "wake-up" feature extends battery life and is complemented by an on/off switch and low battery indicator. The self-storing wireless USB nano receiver makes this an excellent choice for the home, office or while traveling for business.
- V7 MV3050 - mouse - 2.4 GHz - black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Black
- 5.8 cm x 9.5 cm x 3.4 cm
- 56.1 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1600 dpi
- Scrolling wheel, battery indicator, power saving automatic sleep function, on/off power switch, Nano wireless receiver
- Battery
- AAA type
- OS Required
- Apple MacOS X 10.x or later, Microsoft Windows Vista / XP / 7 / 8
- 2-year warranty
- Mouse
- Wireless Receiver
- 5.8 cm
- 9.5 cm
- 3.4 cm
- 56.1 g
- Black
Input Device
- Wireless
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 6 m
- Optical
- Buttons Qty
- 3
- 1600 dpi
- 1 x USB 2.0 - 4 pin USB Type A
- FCC, RoHS; USB 2.0 Full-Speed
- AAA type
- OS Required
- Limited warranty - 2 years
