Enjoy all day comfort with the full size 2.4 GHz wireless Blue Trace mouse that is Windows 8 optimized with two hot key buttons for charm menu and application switching. The 5 button mouse works on virtually any surface and includes a built-in scroll wheel for quick navigation. The 1600 dpi high performance optical LED sensor provides smooth and precise cursor control on large high resolution displays. This mouse is beautifully sculptured with a contoured shape, soft rubber grips, curved sides and broad palm area to reduce fatigue while enhancing the aesthetic appeal of your desktop. The smart power management "wake-up" feature extends battery life and is complemented by an on/off switch and low battery indicator. The self-storing wireless USB nano receiver makes this an excellent choice for the home, office or while traveling for business.
- V7 MV5000 - mouse - black with blue
- Mouse
- Connectivity Technology
- Wireless
- Black with blue
- 6.8 cm x 11 cm x 3.8 cm
- 71.1 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 5
- Movement Resolution
- 1600 dpi
- Scrolling wheel, Blue Trace Technology
- OS Required
- Apple MacOS X 10.x or later, Microsoft Windows Vista / XP / 7 / 8
- 2-year warranty
- Mouse
- Wireless Receiver
- 6.8 cm
- 11 cm
- 3.8 cm
- 71.1 g
- Black with blue
Input Device
- Wireless
- Optical
- Buttons Qty
- 5
- 1600 dpi
- 1 x USB 2.0 - 4 pin USB Type A
- OS Required
- Limited warranty - 2 years
