Get contoured comfort and optimum ease of use with the V7 Standard USB or V7 Standard PS2 mouse. Its plug-and-play functionality provides simplicity, while V7's sleek textured plastic provides maximum precision with minimal mouse movement. The mouse is 100 percent compatible with Windows 2000/XP/Vista or above and features 1000 dpi resolution with a comfortable built-in scroll wheel.
- V7 M30P20-7E - mouse - PS/2 - black
- Mouse
- Connectivity Technology
- Wired - PS/2
- Black
- 6.1 cm x 11.6 cm x 4 cm
- 100 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Scrolling wheel
- Cables Included
- 1 x mouse cable - integrated - 1.5 m
- OS Required
- Microsoft Windows 2000/ME/XP/Vista/7
- 2-year warranty
- Mouse
- 6.1 cm
- 11.6 cm
- 4 cm
- 100 g
- Black
Input Device
- Wired
- Interface
- PS/2
- Optical
- Buttons Qty
- 3
- 1000 dpi
- Scrolling wheel
- 1 x mouse - 6 pin mini-DIN (PS/2 style)
- Cables Included
- Plug and Play
- OS Required
- Limited warranty - 2 years
