The MV3000 full sized Plug & Play USB optical LED mouse has a comfortable universal design with seamless point and click interaction. This high quality space saving 3 button mouse includes a built-in scroll wheel with enhanced tactile button and tracking feedback. The 1000 dpi optical sensor provides precise and swift cursor movement for easy smooth navigation. The professional brush finish will bring style and improved performance for your high volume workload at the home, office or while traveling for business.
- V7 MV3000 - mouse - USB - black
- Mouse
- Connectivity Technology
- Wired - USB
- Black
- 6.4 cm x 12.4 cm x 3.8 cm
- 95 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Scrolling wheel
- OS Required
- Apple MacOS X 10.x or later, Microsoft Windows Vista / XP / 7 / 8
- 2-year warranty
- Mouse
- 6.4 cm
- 12.4 cm
- 3.8 cm
- 95 g
- Black
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 3
- 1000 dpi
- Scrolling wheel
- 1 x USB 2.0 - 4 pin USB Type A
- Plug and Play, FCC, RoHS
- OS Required
- Limited warranty - 2 years
V7 Optical Mouse USB 3 button wheel mouse
